20 Most Recent
McCulloch MC1246 Handheld Steam Cleaner Questions & Answers
How do you thraed the
Take a length of about 6 foot of line, kink it in the middle and pass this through the hole in the spool. Wind the two lengths of line around the spool in their own divisions and in the same direction. The direction of wind is embossed in the reel and the line should be wound tightly and held all the while. When you have about 6-8 inches left in your hand, bring the cover up to the spool and carefully pass the two ends of the line through the holes, push the cover all the way over while pulling on the two pieces of line and ensuring that the lines stay on their own side of the division on the spool. Fit and tighten the bump nut and trim the lines to just about the cut-off blade.
The lines should trail out of the holes in the direction of the machine's rotation. Try cut with the tip of the line as much as possible. Cutting nearer the drum flexes the line and will lead to early breaking of the lines. Run the motor at a constant speed and rather move the cutting head in and out of the weeds to affect a deeper cut
6/30/2011 4:16:32 PM •
McCulloch...
Answered
on Jun 30, 2011
How do i fix a vacuum line hose on a car that's been cut?
Alot depends on the type of hose. There are plastic hoses and rubber hoses. Generally you can use a smaller plastic connector to connect two rubber hoses together and visa versa, Make sure it is a snug fix. You could also use an adhesive to keep it together.
3/31/2024 3:39:13 PM •
Vacuums
Answered
on Mar 31, 2024
