20 Most Recent Optoma EzPro 739 Multimedia Projector Questions & Answers
0answers
2answers
No Power
me too anyone find a fix?
9/26/2013 12:49:50 AM • Optoma EzPro 739... • Answered on Sep 26, 2013
Optima hd65 not powering on when plugged in
Are you getting any lights?
12/27/2012 4:15:54 PM • Optoma EzPro 739... • Answered on Dec 27, 2012
0answers
3answers
Need new color wheel for EP 759
i would try to email optoma or parts guy localy that sell or fixes these see if he can order u it ok best way thx nick
3/26/2012 5:24:04 PM • Optoma EzPro 739... • Answered on Mar 26, 2012
Optoma color wheel issue
Hi Brad
You'll have to go into the service menu and check if all the colours are showing the same percentage.
We normally set all of them on 50%
5/27/2011 6:03:40 PM • Optoma EzPro 739... • Answered on May 27, 2011
OPTOMA EP739 KEEPS OVERHEATING
Clean out the filter.
2/14/2011 4:20:50 PM • Optoma EzPro 739... • Answered on Feb 14, 2011
2answers
Optomoa EZ739 frequent over heating
Still need an answer, but not going to pay for one.
4/23/2010 8:07:24 PM • Optoma EzPro 739... • Answered on Apr 23, 2010
2answers
No power to optoma ezpro 739
check the door(cover) of lamp not closed firmly open it and close it firmly.
1/17/2010 11:21:41 PM • Optoma EzPro 739... • Answered on Jan 17, 2010
The projector powers on and
Hi
Thanks for using FixYa. Please check all input cables coming into the projector. Make sure that all connections are firm & tight. Try using DVI cables if you are using component cable or vice versa. If this doesn't help then make sure that the cooling fan is working and dust filters are not clogged with dust.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
10/8/2009 8:32:31 PM • Optoma EzPro 739... • Answered on Oct 08, 2009
3answers
Installed new color wheel not working correctly
Hi danny,
I also replaced the color wheel in my EP739 after the old one disintegrated suddenly. Colours were then all over the place. Actually, it looked like each colour channel was displaying all the colours of the rainbow!
Here is the procedure I used to solve the problem - maybe not as elegant as Marrie's solution, but it will not cause any damage, will most likely solve the problem, and you will be able to get everything back to the way it was if it doesn't work:
  1. Have the projector running and displaying a stationary picture. The right sort of picture to use is one that has a full range of brightness values from near-black to peak white. I used my lap-top as the source. Also, this way you can compare the projector's picture with the picture on the lap-top.
  2. Press the power button once. "Power off the lamp" dialogue box appears. Hold down the left arrow button until the service menu appears (takes about 8 seconds).
  3. Using the up/down arrow buttons, scroll down to "Color Setting" and press "enter".
  4. Scroll up to "Color Wheel Index". Make a note of the existing setting for later reference. You can change the Index setting over a range of 100 to 550 by holding down the left/right arrow buttons. As the setting changes, the colour rendition will slowly change, and at some point the colours will come right. Note that the changes are quite slow. Find the lower and higher settings where colour aberrations just start to appear, and set the Index mid-way between.
  5. If this doesn't fix the problem, return the Index setting to original. My original setting was 354 and the new setting was 461.
I do not advise touching any other settings in the service menu unless you have access to a service manual and know what you are doing.
Father Dave
4/8/2009 6:32:24 AM • Optoma EzPro 739... • Answered on Apr 08, 2009
My projector has vertical lines on display;
Hi there
This is a common problem on a faulty Mainboard of a Projector.
Not much you can do about it except repair or replace the Mainboard
3/14/2009 11:19:55 PM • Optoma EzPro 739... • Answered on Mar 14, 2009
Projector has no power
close lamp compartement door firmly because door switch can disconnect power from projector if not closed firmly.
12/7/2008 3:04:44 PM • Optoma EzPro 739... • Answered on Dec 07, 2008
Over temp
The heat is generated by the lamp whether or not there is an input signal. If the unit seems to be hotter than normal, check the air input grill and be sure that it is celar of dust and debris. You can also gain access to the fan and be sue that the fan is clean.
Dan
11/17/2008 2:06:42 PM • Optoma EzPro 739... • Answered on Nov 17, 2008
2answers
Optoma EP739
i have the same projector with same problem. i called optoma direct and ordered a new color wheel. it was relatively easy and came in about a week. the phone no. is 408-383-3710
11/13/2008 9:48:53 PM • Optoma EzPro 739... • Answered on Nov 13, 2008
Color bleed and Fan
I had similar problems with my EP739 shutting down in the middle of a presentation. Optima told me to run the fan on the high altitude setting. But the real problem was I was setting the computer too close to the projector, and the hot air from the computer was being sucked into the projector. Once I learned to set the computer away from the vents on the projector, the problem went away.
Doug H.
10/9/2008 12:56:45 PM • Optoma EzPro 739... • Answered on Oct 09, 2008
No signal
switch your lap top first and the projector second----check input is assigned to computer-------press fn key with conjunction of f4 or f5 or f6 or f8.
9/23/2008 8:55:27 PM • Optoma EzPro 739... • Answered on Sep 23, 2008
Optoma EzPro 739 Multimedia Projector Logo
34 questions posted
Top Optoma Office Equipment & Supplies Experts
Muzahura Frank
Marvin
Marvin
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Optoma Office Equipment & Supplies
Most Popular Question
installed new color wheel not working
  • Office Equipment & Supplies
