20 Most Recent Staples SPL1201X (CrossCut) Shredder Questions & Answers
The door you are referring to would be the paper door on the shredder. As for the wheels, ask someone at staples, or check for a similar wheel at home depot, and see if you can replace it.
Staples SPL1201X... | Answered on Jul 03, 2011
That is because when you turn it off the cooling fan stops and if you have been using it a lot, the heat immediately builds up and it trips the overheat switch.
If should restart after about an hour. Unless it is an industrial shredder, you should use it no longer that 5 minutes. Shred a little and often.
Staples Office... | Answered on Apr 28, 2020
IF YOU LOOK INTO THE SLOT WHERE YOU FEED THE PAPER...GET A FLASHLIGHT ........IN THE MIDDLE OF THE SLOT YOU WILL SEE A TINY SWITCH. THAT THING SOMETIMES GETS GUMMED UP WITH GLUE FROM ENVELOPES AND SUCH... TRY SOME WD-40 ON THAT SWITCH... WITH THE MACHINE UNPLUGGED PUT PAPER IN THE SLOT TO MOVE THE SWITCH SO THE WD-40 CAN LOOSEN UP ANYTHING .... THEN TRY BLOWING AIR IN IT....
ARE YOU SURE THAT THE TOP OF THE SHREDDER IS SITTING FLUSH WITH THE PORTION IT RESTS ON??? THAT COULD ALSO MAKE IT NOT WORK..... OR IF THE BASKET NEEDS EMPTYING THE TOP WONT REST FLUSH ON THE BASKET.
Staples Office... | Answered on Feb 18, 2020
ask google or your local home improvement store
Staples Office... | Answered on Nov 23, 2019
Usual cause is paper jammed in the cutting heads.
Staples Office... | Answered on Sep 17, 2019
Staples SPL1201X (CrossCut) Shredder Logo
13 questions posted
Top Staples Office Equipment & Supplies Experts
John mullen
gbob59
Marvin
Marvin
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Staples Office Equipment & Supplies
Most Popular Question
when shredder
  • Office Equipment & Supplies
