20 Most Recent
Fellowes P48C Cross Cut Shredder with Patented Safety lock Questions & Answers
My fellowes p 48c is jammed
It maybe that the shredder cutters are jammed. Unplug from mains, and lift off top and
place upside down. Use a small screwdriver and poke at any compressed paper
wrapped around the blades - can take a while.
Give a quick spray to cutters with WD40 Replace - turn on - and run in reverse.
If all else fails, contact the maker
New and will not come on
If you have taken the safety lock off and it still does not work then return it as faulty.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
My fellowes paper shredder is
Instructions
Step 1
Shut off the shredder. Unplug it and let in cool down for up to one hour. This will work if the shredder has stopped due to excessive use.
Step 2
Check to see if the shredder is jammed. This is the most common cause of shredder problems. Click the power switch to reverse, which should clear a minor jam. If not, set the shredder to auto, and then to reverse again until the jam clears.
Step 3
Clear extremely stubborn paper jams by grabbing the stuck paper and gently pulling it out. If smaller pieces of paper cause the jam, shut off the shredder and unplug it. When it cools down, carefully use a pair of tweezers to remove the paper bits.
Step 4
Determine if the power supply to the shredder is working properly. If the power supply is cold, use an alternative source of electricity for your shredder. If it is warm, there may be a problem with the shredder itself. Call your office machine repair shop or the shredder manufacturer for assistance.
Step 5
Sharpen or oil the blades. Shredder blades need to be oiled on a regular basis to keep your machine in proper working order. Get oil made specifically for shredder blades from an office supply store.
Good Luck!
What is the fiscal size of Fellowes shredder?
Question edited for clarity, spelling of 'Fellowes'.
I don't think 'fiscal' means what you think it means?
fis·cal
/?fisk(?)l/
adjective
relating to government revenue, especially taxes.
"monetary and fiscal policy"
Fellows does all sizes of shredders up to Office Quality machines that will also Crosscut shred credit cards and CDs.
https://www.google.com/search?q=Fellowes+shredders
