20 Most Recent Canon IR1018J Black and White Copier Questions & Answers
Main cause The laser driver/BD PCB is faulty (laser activation failure, BD
detection fault). The DC controller PCB is faulty. The image
processor PCB is faultly.
or drum is faulty.
Canon IR1018J... | Answered on Dec 10, 2017
E019 means your waste tank is full. In iR1018/iR1020 series copier, waste tank is located at drum unit. First, remove the drum unit from the machine. Second, open the white plastic lid of the waste container. Third, drain the waste. Re-fit the plastic lid of the waste container and re-insert the drum.
Canon IR1018J... | Answered on Mar 13, 2017
If the problem is simply that the machine is not feeding paper, you should clean the paper pick up and feed rollers. Typically there will be one attached or above the paper tray(s) and a couple that transfer the paper through the machine to the print drum and fuser. Find them and clean them with clean cloth wet with a dilute solution of dish wash detergent with a few drops of methylated spirit or isopropanol mixed in. If paer then feeds but no print - you have more serious issues.
Canon IR1018J... | Answered on Sep 06, 2016
Have you tried pulling out toner cartridge and shaking it? Does this fix it for a short period. Make sure you are purchasing a quality toner. Thank you so much. Leave feedback and let us know.
Canon IR1018J... | Answered on Jul 11, 2016
Go to canon official download centers
canonusa.com
Canon IR1018J... | Answered on Mar 28, 2015
I have one of these: the IR1022iF. Have you got the complete error code, please?
Canon IR1018J... | Answered on Feb 14, 2015
Dear
It is due to the consumable problem check the following
1- check the drum life> if possible clean the PCR roller with isopropyle alcohol, clean the drum blade.
2- detach the developer assy. and turn the mag roller to check the even flowing of toner, if you are experience clen the doc. blade and roller bushes of the developer assy.
3- check the transfer roller and its contact points clean it with soft anti static brush.
Thanks.
Canon IR1018J... | Answered on Jan 16, 2015
This error is related with the laser unit. Disassemble that unit and clean the internal mirrows, if problem persist replace the laser unit
Canon IR1018J... | Answered on Apr 17, 2014
BD detection PCB failure
The BD detection PCB is faulty.
check laser shutter
Canon IR1018J... | Answered on Feb 17, 2014
REPLACE MAIN BOARD ? HOW ABOUT BUYING ANOTHE PRINTER ? O_o
Canon IR1018J... | Answered on Nov 18, 2013
http://lmgtfy.com/?q=Canon+IR1018J+driver
Canon IR1018J... | Answered on Nov 15, 2013
E019 0000 Waste toner full detection The waste toner full state was detected.
Canon IR1018J... | Answered on Jun 13, 2013
you need a special service tool to load the firmware to the copier and usually only canon sevice technicians have access to it,
you may need to call a canon agent service centre
Canon IR1018J... | Answered on May 22, 2013
Canon IR1018J Black and White Copier Logo
54 questions posted
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
system error e100 canon ir1018
  • Office Equipment & Supplies
