20 Most Recent Xerox WorkCentre 52255230 Copier Questions & Answers
0answers
How to fix xerox docucentre 2056 error 010-327
That error signifies a defective fuser, not coming to temperature. Replace fuser, part number 126K24980. See link below: http://www.iteminconline.com/126k24980_126k24980-126k24981-126k24982-126k24983-126k24984-xerox-workcentre-5225-5230-fuser-110v-new.htm
3/30/2016 10:26:33 PM • Xerox WorkCentre... • Answered on Mar 30, 2016
What does 012-132 fault code mean
Here is a link to the service manual: http://www.scribd.com/doc/86553381/XEROX-Work-Centre-5222-5225-5230-Service-Manual-Pages#scribd 012-132 RAP Finisher Transport Entrance Sensor ON Jam (Long).
3/16/2015 8:31:10 PM • Xerox WorkCentre... • Answered on Mar 16, 2015
Error Cod 124 315 In Xerox WorkCentre 52255230 Copier
i think drum is not rotating check for bearing
2/22/2014 6:12:11 PM • Xerox WorkCentre... • Answered on Feb 22, 2014
I hv a error code...fuji
Xerox dc a 450 error code 010-352
9/21/2013 1:39:19 AM • Xerox WorkCentre... • Answered on Sep 21, 2013
I have a WC5225. When
Try this: 1. Turn machine off 2. After it has completely powered down, unplug the power cord from the wall. 3. Go back to the front of the machine and turn it on and then back off again (remembering to leave it UNPLUGGED from power.) 4. WAIT 60 SECONDS (Very important) 5. AFTER 60 seconds plug it back into the wall and turn it back on.
If problem persists call for service.
Hope it helps!
5/29/2011 5:32:28 AM • Xerox WorkCentre... • Answered on May 29, 2011
I have received an error code of 010-327 and I
Fuser thermal error. Check for paper wrapped around the rollers, but you will need to replace it.
PN 126K24980
Whit
Item, Inc.
8/13/2010 10:59:28 PM • Xerox WorkCentre... • Answered on Aug 13, 2010
2answers
Xerox Phaser 7100. Error 060310?
Question edited for clarity and typo.
Fault Code 060-310: Warm Up Failure - Support - Xerox
Xerox https://www.support.xerox.com > en-ie > article Fault Code 060-310: Warm Up Failure. Article Id: 1715946 ' Published: 11/09/2016. Product support for. Phaser™ 7100 ...
Error Codes > Xerox > Phaser 7100 > Code 060-310, 061-340 ...
PrintCopy .info https://printcopy.info > code=060-310, 061-340, 061-... Xerox Phaser 7100 · Code: 060-310, 061-340, 061-346 · Description: ROS Failure Laser error has occurred due to one of the following problems. The SOS is unstable ...
3/9/2023 7:13:24 AM • Xerox Office... • Answered on Mar 09, 2023
Xerox 7435 error 041-340 how to solve error
Xerox 7435 error code 041-340 indicates a problem with the yellow imaging unit. Here are some steps to solve the error:
  1. Power off the printer and unplug it from the power source.
  2. Remove the yellow imaging unit and check for any damage or leaks.
  3. If the imaging unit appears to be in good condition, reinsert it firmly and make sure it is properly seated.
  4. Turn the printer back on and check if the error message has disappeared.
  5. If the error persists, try replacing the yellow imaging unit with a new one.
  6. If replacing the imaging unit doesn't solve the problem, you may need to call a technician to troubleshoot the issue further.
It's worth noting that error code 041-340 can also be caused by issues with the developer housing, toner cartridge, or other components. If none of the above steps work, it's best to contact Xerox support for assistance.
2/27/2023 5:47:34 PM • Xerox Office... • Answered on Feb 27, 2023
2answers
What does error code 99,013.00:49569 mean xerox 8570 color cube?
Process Drive Fault" Do you have another kit you can take from another printer. Switch the printer off. Swap out the kit with the one from the other printer. Turn it back on. If it clears the fault when the printer is ready put back the new kit
2/25/2023 6:29:35 PM • Xerox Office... • Answered on Feb 25, 2023
Are refurbished Xerox 7760 imaging drums safe to use?
Refurbished imaging drums can be a good option to save money, but it is important to purchase them from a reputable source to ensure they are of good quality and safe to use. Some refurbished parts may not be manufactured to the same standards as new parts, which can affect the performance and lifespan of your printer. When purchasing refurbished imaging drums, look for sellers who offer a warranty or guarantee on the product. This can provide added peace of mind and protection in case the drum fails prematurely. Additionally, be sure to follow the manufacturer's instructions for installation and maintenance to ensure optimal performance and avoid any potential issues.
2/25/2023 3:33:49 PM • Xerox Office... • Answered on Feb 25, 2023
On a xerox xc1250 what does a status code h3 mean and how do I fix it or reset it.
On the Xerox XC1250 copier, the status code H3 indicates a high-temperature error in the fuser section. This error occurs when the fuser unit gets too hot, and the copier automatically shuts down to prevent damage. To resolve the issue, try the following steps:
  1. Turn off the copier and unplug it from the power source.
  2. Wait for about 20 minutes to allow the fuser unit to cool down.
  3. Check the fuser unit for any signs of damage, such as cracks or burns. Replace the fuser unit if necessary.
  4. Check the power supply and make sure it is delivering the correct voltage to the copier.
  5. Plug the copier back in and turn it on.
If the error code persists after trying the above steps, it may be best to contact a Xerox service technician for further assistance. They will have the necessary tools and expertise to diagnose and fix the issue.
2/24/2023 10:08:52 PM • Xerox Office... • Answered on Feb 24, 2023
2answers
How to solve the LL- 21 xerox wide format 8830
1. Check the user manual for the Xerox Wide Format 8830. This should provide instructions on how to troubleshoot and solve any issues you may be having with the machine. 2. Contact Xerox customer service for assistance. They should be able to provide you with more detailed instructions on how to solve the issue. 3. If the issue is related to a hardware or software issue, you may need to contact a qualified technician to come and repair the machine.
2/23/2023 9:47:19 PM • Xerox Office... • Answered on Feb 23, 2023
Reset the forgotten Xerox workcentre 3225 admin password
If you have forgotten the admin password for your Xerox WorkCentre 3225, you can reset it to the default factory settings using the following steps:
  1. Turn off the printer: Turn off the printer and unplug it from the power source.
  2. Access the control panel: Press and hold the "0" button on the printer's control panel while turning on the power switch. Keep holding the "0" button until "Accessing Service Menu" appears on the display.
  3. Access the Diagnostics menu: Press the "Up" or "Down" arrow button until "Diagnostics" is highlighted on the display, then press the "OK" button.
  4. Access the Service Tools menu: Press the "Up" or "Down" arrow button until "Service Tools" is highlighted, then press the "OK" button.
  5. Reset the password: Press the "Up" or "Down" arrow button until "Reset Password" is highlighted, then press the "OK" button. Enter "1111" when prompted for the password and press the "OK" button.
  6. Restart the printer: Press the "Up" or "Down" arrow button until "Restart System" is highlighted, then press the "OK" button. The printer will restart and the password will be reset to the default.
Note that resetting the password to the default will remove any custom settings or configurations you have set up on the printer. It's also important to note that some models of Xerox printers may have slightly different steps, so it's always best to refer to the user manual or contact Xerox support for assistance if you're unsure about any of these steps
2/17/2023 1:42:01 PM • Xerox Office... • Answered on Feb 17, 2023
Xerox Versalink C7025 error code 116-331
This error code could indicate an issue with the drum or fuser. Ensure that the toner cartridge/drum has been seated correctly, and if necessary contact a qualified technician or Xerox support to further investigate and resolve the issue.
2/14/2023 6:23:44 PM • Xerox Office... • Answered on Feb 14, 2023
A problem with Xerox WorkCentre 7845
The error code 303.777.00 on the Xerox WorkCentre 7845 suggests a problem with the power supply. Since the machine is restarting on its own every 20 minutes, it is likely that the power supply is failing. You should contact Xerox customer support for assistance, and a trained technician should diagnose and repair the power supply to fix the problem.
2/14/2023 11:42:08 AM • Xerox Office... • Answered on Feb 14, 2023
Xerox WorkCentre 52255230 Copier Logo
15 questions posted
Top Xerox Office Equipment & Supplies Experts
Gary
Gary
Clive
Clive
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Xerox Office Equipment & Supplies
Most Popular Question
wc5225 when
  • Office Equipment & Supplies
