20 Most Recent Toshiba estudio 305 Copier Questions & Answers
Simply go into the printer driver and set paper format for A3, and set it also in the application that you are using (Ex. Word 2016)
Best Regards
Toshiba estudio... | Answered on Jul 24, 2016
Stop jam at the exit sensor: The trailing edge of the
original does not pass the exit sensor
Toshiba estudio... | Answered on Jun 26, 2016
"Store the update program loader (mentusb2.o) in the root directory, and store" Is that the directory you mean? The 'root directory' is a computer term Maybe goto here:
http://fyi.toshiba.com:81/KB/file_uploads/7802/es455-manual-update-instructions.pdf
Toshiba estudio... | Answered on May 22, 2016
If you are not a printer/copier technician my best advice: Don't mess with your copier. Call an authorized sevice. you might need to check electronic circuits, boards, componentes, etc.
Toshiba estudio... | Answered on Oct 28, 2015
Try initialise the HDD ( 08-690 ), is still persist, HDD might be problem.
Toshiba estudio... | Answered on Mar 13, 2015
down load the driver from www.wordcraft.com
Toshiba estudio... | Answered on Feb 20, 2015
First, make sure you have a Toshiba authorized toner.
There is also a switch at the rear of the machine that does go bad, sometimes just by cleaning the cavity with a vacuum may correct the problem but ive had to replace the switch before. Not something a non tech person can do.
Toshiba estudio... | Answered on Jan 04, 2015
Check all the paper path. Ther might be a stuck up sensor not in home position or a small torn paper stuck up or left behind the sensors ..
Toshiba estudio... | Answered on Nov 25, 2014
Place the original documents facing up to the Automatic Document Feeder then press the START key ..
Same way only tell it to use the top feeder.
Toshiba estudio... | Answered on Sep 13, 2014
The 305 & 350 take different HDD's but both will need firmware loaded in 4/9 mode after replacement.
Toshiba estudio... | Answered on Aug 06, 2014
About a lack copy
Toshiba estudio... | Answered on Jul 06, 2014
Replace with original toner cartage.
press 0 & 5 simmilutely m/c. on type 200 press start m/c. is moving you see screen when figure is going 230 to 245 then press enter then press intruppt hope your m/c. ready
Toshiba estudio... | Answered on Feb 24, 2014
user funcion-user-drawer
disable all these options
thichi-insert-cover-special
Toshiba estudio... | Answered on Dec 10, 2013
try to press clear+8 to show what error code is indicating.tell me what error code is that.
Toshiba estudio... | Answered on Nov 18, 2013
Toshiba estudio 305 Copier Logo
56 questions posted
Top Toshiba Office Equipment & Supplies Experts
Timothy Van Der...
Muntejaya Ginting
Muntejaya Ginting
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Office Equipment & Supplies
Most Popular Question
giving error place doc feeder in down
  • Office Equipment & Supplies
