20 Most Recent Hitachi Cpx2510 Projector Cpx2510 Xga Projector Lamp Questions & Answers
the lamp is broken ,yuo need a new one We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel, motherboard, powersupply ... with high quality and competitive price. any questions, feel free to contact me have a nice day! Jerry Lampdeng Limited
Hitachi Cpx2510... • Answered on Apr 02, 2015
1,Check the fans ,whether the fan is running,when you turn on the projector 2,if the fans run, then ,check the lamp or lamp ballast We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel, motherboard, powersupply ... with high quality and competitive price. any questions, feel free to contact me have a nice day! Jerry Lampdeng Limited
Hitachi Cpx2510... • Answered on Jan 06, 2015
it sounds like you have a broken power board
Hitachi Cpx2510... • Answered on Jun 16, 2014
hi,
Its because you projectors lamp have to replaced. It is notifying that you have to replace the lamp. if you wish to use the same lamp then you have to reset the lamp hour timer. it is recommended that you have to reset the lamp hour only after replacing the lamp. do the following for reset you projectors lamp hour.
(1) Press the MENU button to display a menu.
(2) Point at the ADVANCED MENU in the menu using
the up arrow/down arrow button, then press the right arrow button.
(3) Point at the OPTION in the left column of the menu
using the up arrow / down arrow button, then press the right arrow button.
(4) Point at the LAMP TIME using the up arrow / down arrow button, then press the right arrowbutton. A dialog will appear.
(5) Press the right arrow button to select "OK" on the dialog. It performs resetting the lamp time.
ok
Hitachi Cpx2510... • Answered on Apr 29, 2011
hi,
Check the lamp cooling fan of your projector . may be its has some problem. its not running at the correct RPM. Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now you can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector. power ON the projector and watch.
Also check the air filter. try to clean the air filter.
ok
Hitachi Cpx2510... • Answered on Apr 09, 2011
Yes, as bulbs age they will begin losing brightness. Most projectors have a bulb life hour clock, that measures the number of hours a bulb has been used. Usually you can pull that up within the menu of the projector. Also that particular model has what is called "Eco-Mode" and when engaged dims the bulb by 25% to cut down on power consumption.
Typical life for a lamp in that projector is:
3000 hours on Normal mode
6000 hours on Eco mode
You can expect a brightness loss of 50% when you are approaching end of a lamps life.
Hitachi Cpx2510... • Answered on Mar 07, 2011
This projector was sold with a 3-year manufacturers warranty. You can contact Hitachi warranty service at 1-800-HITACHI.
If you have a continuing issue or support problems, contact me directly at [email protected]
Hitachi Cpx2510... • Answered on Oct 27, 2010
BILLY, Your message does not qualify as a question or query for a problem, try somewhere else DO NOT MAKE THIS SITE WITH YOUR GARBAGE Take your GARBAGE to another Side Your message qualifies as SPAM
Hitachi Office... • Answered on Nov 06, 2019
Hi Sam, the temperature light, tells you that the ventilation system is not working properly As a first step, remove the filter (s) and clean them well or replace them with new filters. It would also be important to do an interior cleaning, do not use torches or air sprays, since they can do more damage than solution, always try to vacuum dirt I hope you can make your Hitachi work properly Regards Franco Dosil Hola Sam, la luz de temperatura, te indica que el sistema de ventilacion no esta trabajando correctamente Como primera medida , saca el o los filtros y limpialos bien o reemplazalos por filtros nuevos Tambien seria importante hacer una limpieza interior, no utilices ni sopletes ni aerosoles de aire, ya que pueden hacer mas da?o que solucion, siempre trata de aspirar la suciedad espero Puedas hacer funcionar correctamente tu Hitachi Saludos Franco Dosil
Hitachi Office... • Answered on Aug 13, 2019
the lamp is not good you need a Original lamp I Supply the Projector accessories,in China. projector accessories:Laser Diode Module,lamp,bulb,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast...with high quality and competitive price. Hope to cooperate with you. Lampdeng Co.,Ltd. (Guangzhou, China) is founded in 2000, is a major supplier of projector lamps www.Lampdeng.com
Hitachi Office... • Answered on May 31, 2019
the Lcd panels are fault or the polarizer isfault I Supply the Projector accessories,in China. projector accessories:Laser Diode Module,lamp,bulb,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast...with high quality and competitive price. Hope to cooperate with you. Lampdeng Co.,Ltd. (Guangzhou, China) is founded in 2000, is a major supplier of projector lamps www.Lampdeng.com
Font strokes are not cleaned Black silk font is not black enough reason: the Lcd panels are fault I Supply the Projector accessories,in China. projector accessories:Laser Diode Module,lamp,bulb,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast...with high quality and competitive price. WhatsApp ID:+8613178867858 Skype:[email protected] Wechat ID:+8613178867858 Email:[email protected] Email:[email protected] Mobile:+86 13178867858 http://www.lampdeng.com
The power indicator is off. two reason: 1,the mainboard is fault 2,the powersupply is fault I Supply the Projector accessories,in China. projector accessories:Laser Diode Module,lamp,bulb,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast...with high quality and competitive price. WhatsApp ID:+8613178867858 Skype:[email protected] Wechat ID:+8613178867858 Email:[email protected] Email:[email protected] Mobile:+86 13178867858 http://www.lampdeng.com
You should clear the air filter and reset the air filter timer and the lamp timer menu-advance-option-reset the air filter menu-advance-option-reset the lamp filter I Supply the Projector accessories,in China. projector accessories:Laser Diode Module,lamp,bulb,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast...with high quality and competitive price. WhatsApp ID:+8613178867858 Skype:[email protected] Wechat ID:+8613178867858 Email:[email protected] Email:[email protected] Mobile:+86 13178867858 http://www.lampdeng.com Posted on May 31, 2019
you should clear the air filter and reset the air filter timer menu-advance-option-reset the air filter I Supply the Projector accessories,in China. projector accessories:Laser Diode Module,lamp,bulb,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast...with high quality and competitive price. WhatsApp ID:+8613178867858 Skype:[email protected] Wechat ID:+8613178867858 Email:[email protected] Email:[email protected] Mobile:+86 13178867858 http://www.lampdeng.com
NO fuse The power indicator is off. two reason: 1,the mainboard is fault 2,the powersupply is fault I Supply the Projector accessories,in China. projector accessories:Laser Diode Module,lamp,bulb,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast...with high quality and competitive price. WhatsApp ID:+8613178867858 Skype:[email protected] Wechat ID:+8613178867858 Email:[email protected] Email:[email protected] Mobile:+86 13178867858 http://www.lampdeng.com
the Lcd panel is fault there are 3 lcd panels in the projector, R G B pink, it seems the Green panel is fault I Supply the Projector accessories,in China. projector accessories:Laser Diode Module,lamp,bulb,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast...with high quality and competitive price. WhatsApp ID:+8613178867858 Skype:[email protected] Wechat ID:+8613178867858 Email:[email protected] Email:[email protected] Mobile:+86 13178867858 http://www.lampdeng.com
Hello Ramesh, I give you the link so you can download the user manual of your cpx3030wn To access the service mode of your cp x3030wn, follow the steps indicated on page 5 of the cp x3021 service manual I give you the link so you can download it I hope you can solve the problem Greetings Franco Dosil Hola Ramesh, Te paso el link para que puedas descargar el manual de usuario de tu cpx3030wn Para acceder al modo service de tu cp x3030wn, sigue los pasos indicados en la pagina 5 del manual de servicio del cp x3021 Te paso el link para que puedas descargarlo Espero puedas solucionar el problema Saludos Franco Dosil https://www.projectorcentral.com/pdf/projector_manual_7503.pdf https://www.projectorcentral.com/pdf/projector_spec_7503.pdf https://elektrotanya.com/hitachi_cp-x3021wn.pdf/download.html
Hitachi Office... • Answered on May 22, 2019
Hi Ramesh, to access the service mode of your cp x3030wn, follow the steps indicated on page 5 of the cp x3021wn service manual I give you the link so you can download it I hope you can solve the problem Greetings Franco Dosil Hola Ramesh, para acceder al modo service de tu cp x3030wn, sigue los pasos indicados en la pagina 5 del manual de servicio del cp x3021wn Te paso el link para que puedas descargarlo Espero puedas solucionar el problema Saludos Franco Dosil https://elektrotanya.com/hitachi_cp-x3021wn.pdf/download.html https://www.projectorcentral.com/pdf/projector_manual_7503.pdf https://www.projectorcentral.com/pdf/projector_spec_7503.pdf
Hitachi Cpx2510 Projector  Cpx2510 Xga Projector Lamp Logo
7 questions posted
Top Hitachi Office Equipment & Supplies Experts
Richard C Cohen
Richard C Cohen
ray gallant
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Office Equipment & Supplies
Most Popular Question
hitachi projector lamp
  • Office Equipment & Supplies
