20 Most Recent Scott LCT37SHA TV Questions & Answers
when ever the remote stops functioning to be certain that the remote is good turn on your camera on your cellphone place the remote in front of the cam and press the keys you should see the IR light every time if not the remote is faulty
Scott LCT37SHA... | Answered on Nov 12, 2015
Check the remote control for its infra-red emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If remote control is OK, check and replace the infra-red sensor inside the TV. Contact any service technician.
Scott LCT37SHA... | Answered on Oct 21, 2014
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Scott LCT37SHA... | Answered on Apr 08, 2014
Check and replace the main power regulator board. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Scott LCT37SHA... | Answered on Apr 07, 2014
Leaving it on overnight is not a problem. 99% chance you have a bad power supply board, 1% it is the main board.
See the following listing for repairing the power supply:
http://www.coppelltvrepair.com/p/785/scott-lct37sha-power-supply-board-repair-serivce-for-totally-dead-not-powering-on-or-shutting-down-tv
Scott LCT37SHA... | Answered on Jan 30, 2014
There are two things you can do: open the TV and examing the power supply board for visually bulged capacitors and replace them yourself.
Or bring or send a board for service to someone who would do it for you, for example
There is also a third option, which is to just get a replcement power supply board. It's not necessarily bad one, but if it is an old and used board that has NOT been serviced and capacitors that tend to go bad replaced, then it will likely do the same in near future.
That is known to sometimes happen...and if it is any consideration it is known to happen accross the board, not just with Scott LCT37SHA :-)
Try a different outlet for a starter, then consdier using this:
Scott LCT37SHA TV Logo
91 questions posted
Top Scott Televison & Video Experts
ray gallant
Watching Him
Watching Him
Are you a Scott Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Scott Televison & Video
Most Popular Question
tv shutting off while watching
  • Televison & Video
