20 Most Recent Sony NWZE345 MP3 Player Questions & Answers
3answers
I have a walkman nwz-e345. Recently the volume has
i have the same exact problem. the volume down button works ok. the volume up button seems to do any of a number of different functions other than turning the volume up again. it has just gotten worse and worse. christ damn i hope someone can figure out a fix.
3/12/2019 8:05:15 PM • Sony NWZE345 MP3... • Answered on Mar 12, 2019
My sony NWZ-E445 is stuck on home screen
I have the same problem here. Looks like the cause is permanent bad sectors in the flash chip, unfortunately there is no fix because it lacks wear leveling (cheap junk chips). If you can rewrite it at a low level there is a small chance it may recover, maybe try and find the _WP pin and bypass it as this works for unformattable pendrives as well.
8/11/2016 7:44:20 AM • Sony NWZE345 MP3... • Answered on Aug 11, 2016
How do i turn it off
Pls read your user guide first.
8/28/2012 11:07:15 AM • Sony NWZE345 MP3... • Answered on Aug 28, 2012
How do i reset my mp3 player its just frozen?
How Do I Fix My Sony MP3 Player That Froze & Won't Turn On?
Sony Walkman MP3 players, like most MP3 players, can occasionally freeze up and stop working properly. Fortunately, there are two simple ways of resetting the Walkman system. The first method takes only 10 to 15 seconds to complete and is an effective way to troubleshoot most technical problems you may have with your Walkman. The second method, unfortunately, may take several hours; it requires you to allow the battery to drain completely. Whatever the problem is that's causing your MP3 player to freeze, one or both of these methods should clear it up.
Instructions
Things You'll Need:
* Paperclip
* Walkman MP3 player charger
Reset Button
Straighten the paperclip and set it aside for now.
Locate the reset button on your Sony MP3 player. On most models, it can be found near the volume control mechanism.
Insert the end of the paperclip into the reset button and hold it down for three to five seconds. When the screen flickers, you'll know that the MP3 player's system has been reset.
Remove the paperclip and wait for the system to reboot.
Battery Drain
Turn on your MP3 player.
Let the battery's life deplete. Since the system is frozen and no music is being played, this will take longer than usual.
Check that the battery is completely depleted. Sometimes the screen just goes dark during this process, but the battery is not actually drained. You can check this by pushing buttons or trying to power up the system.
Connect your MP3 player to its charger and plug it in to a power source. Allow the MP3 player to fully recharge.
Power on the MP3 player. The system should be operating normally again.
10/27/2011 6:51:05 PM • Sony NWZE345 MP3... • Answered on Oct 27, 2011
PC no longer recognizes my
Hi loreo88...
Go to Device Manager
To get to Device Manager you will:
Right click on My Computer>Properties>click the Hardware Tab>Device Manager.
After you are in Device Manager look for your MP3 player or Unit.
Here you should see no "Yellow" exclamation points.
If you do they they are telling you that you have a device conflict.
If you currnetly have your unit plugged in, you may notice the "unknown device" which would be your Player or Unit.
If you unit has an exclamation point by it, then you will need to click on it and delete it.
After you remove all devices with conflicts then click on refresh and search again for your MP3 player/Device.
The computer should install your device this time and solve your problem with connection of the MP3 player/Device.
Please take time to rate me thumbs up.
9/21/2011 11:51:17 PM • Sony NWZE345 MP3... • Answered on Sep 21, 2011
When I plug my player
Go to My Computer , right click to get properties. go to third tab hardware and then device manager. Go to very last Universal serial bus controllers. Delete them all . and restart your PC or laptop.
This way your windows will install fresh USB drivers automatically.
5/3/2011 5:46:25 AM • Sony NWZE345 MP3... • Answered on May 03, 2011
My windows xp laptop wont
may be you may have to provide with the device driver or if it is installed you may have to reinstall it.
check the device in other PC to check whether it is the problem of the hardware or not
please got o device manager and check whether the status are proper (enable the device if it was disabled) please check in all ports check for viruses check the antivirus solution whether this hardware is blocked or not thanx PLZ VOTE
4/8/2011 4:39:08 AM • Sony NWZE345 MP3... • Answered on Apr 08, 2011
How do i trun it on?
3/11/2011 6:17:50 PM • Sony NWZE345 MP3... • Answered on Mar 11, 2011
When i plug it to laptop it doesnt show up when i
http://esupport.sony.com/CA/perl/swu-list.pl?mdl=NWZE345&SelectOS=28
just download that and it should register in your computer
2/28/2011 3:59:18 PM • Sony NWZE345 MP3... • Answered on Feb 28, 2011
I have 600 songs in memory and when I try to add
probably even if its 16GB sometime files goes error. check if it has enough space left to store songs... or try to save all your songs first then format it and the save your songs again try if all the songs will be stored after you format.
6/6/2010 2:22:47 AM • Sony NWZE345 MP3... • Answered on Jun 06, 2010
Mp3 wont turn on or charged
format it completely
5/21/2010 1:03:03 AM • Sony NWZE345 MP3... • Answered on May 21, 2010
Sony MHC-RV5 Stand By issue
Could be an open internal fuse or power supply failure
7/23/2021 9:42:48 PM • Sony Audio... • Answered on Jul 23, 2021
3answers
How to repair SONY HCD-ZUX10D DVD DECK RECEIVER always display EJECT and then STANDBY ?
https://community.sony.co.uk/t5/home-cinema-projectors-players/how-to-repair-sony-hcd-zux10d-dvd-deck-receiver-always-display/td-p/2295791
7/20/2021 1:51:12 PM • Sony Audio... • Answered on Jul 20, 2021
Pioneer VSX-D498 gets no audio from Sony Bluray UBP-X700
There are caps on the cable ends that have to be removed. Then you insert it in the device
7/19/2021 1:45:22 AM • Sony Audio... • Answered on Jul 19, 2021
Sony TA-AV421 Sound System connecting to Sony Bravia TV, no sound.
go to the shop and ask for USB/HDMI cable
7/17/2021 9:47:40 AM • Sony Audio... • Answered on Jul 17, 2021
Sir, Is it possible to rewind the power supply transformer of Sony CMT-ED1 component?
Yes there are companies that rewind transformers. Or You can purchase or use any power supply as long as the voltages are okay. Sony are very well known for doing things differently. Here is the service manual. https://www.manualslib.com/manual/697827/Sony-Hcd-Ed1.html ..
7/11/2021 6:09:58 PM • Sony Audio... • Answered on Jul 11, 2021
Sony NWZE345 MP3 Player Logo
33 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
 Francisco Mauricio...
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
pc no longer recognizes
  • Audio Players & Recorders
