20 Most Recent Motorola Mobility DCH3416 (160 GB) DTV Receiver Video Recorder Questions & Answers
0answers
My comcast supplied DCH3416 started
Do not sweat it - the unit is rented so call and get replacement free of charge from Comcast.
8/25/2017 2:18:36 PM • Motorola... • Answered on Aug 25, 2017
0answers
0answers
Looking for ir extender / blaster to put motorola dch3416 into closet.
Probably best to go to Best Buy or Fry's or some other electronics solutions store where they can recommend a solution. You may find audio visual online communities discussing this. Mark Motorola Support
2/10/2015 12:15:49 PM • Motorola... • Answered on Feb 10, 2015
Audio does not match the video
I have some bad new if you go to google and type in "Motorola DCH3416 lagging audio" you will see this is a common issue with the lag being upward of 10 to 60 seconds. No solution at this time has been found.
4/9/2014 11:45:53 PM • Motorola... • Answered on Apr 09, 2014
0answers
Eas code
Be the first to answer 1/3/2014 3:35:35 AM • Motorola... • Posted on Jan 03, 2014Be the first to answer
0answers
Charter code s0900
Be the first to answer 12/31/2013 3:45:22 AM • Motorola... • Posted on Dec 31, 2013Be the first to answer
When you try to view
i had a similar problem with an IR system once. thats the thing that makes it so you can hide the box in a closet so you dont have to see it. it was the ir that was the problem and ABT replaced it. try to find out if the box or the remote causes it. maybe a down button is stuck in on one or the other. if you put away the remote and use the buttons on the front of the box does it still happen? good luck
11/14/2013 4:52:36 PM • Motorola... • Answered on Nov 14, 2013
Connect headphones to dvr model
you would need a "doggle" to switch from stereo (the red and white near the yellow on the back) to headphone. i have seen the sort of thing at best buy and radio shack. good luck
11/14/2013 3:58:03 PM • Motorola... • Answered on Nov 14, 2013
Doesn't receive signal from remote control
if it works intermittenly then the remote dosent need reprogrammed. SOoooo.... line of site comes to mind. your box needs to see what your remote shoots out. sometimes something ends up in front of the reciever spot on the cable box (FYI: a flashlight at the right angle can help find the sweet spot on most devices) maybe the dvr is going bad watch EVERYTHING you want to see one last time and have it swapped (like death, you can't take anything with you) good luck (I hope its just a line of sight problem)
11/14/2013 2:38:09 PM • Motorola... • Answered on Nov 14, 2013
Dch3416 cable display zero??
the box is missing all its channel line up info best case sanario in 1/2 hour it will be done downloading it all again. too impatient to wait? 1) turn everything on as if it was working. 2) press power to turn off the cable box only (leave the tv on) and begin pressing ok or select over and over right away. may take a couple tries 3) you see a white screen with black text? select OOB and see if it says good or at least fair 4) select inband and see if it says good or atleast fair 5) if both good or fair wait; else make certain all cables are tight then check again 6) if they are NA or poor or anything of the sort call your cable operator good luck get a tivo ;}~
11/13/2013 10:15:53 PM • Motorola... • Answered on Nov 13, 2013
TV will not display picture or sound except for 1
DONT USE the remote that came with your TV use the buttons on the box to change the channel. did the channel change? usually when someone only has one channel its because they are changing the tv channel not the cable box channel think of it like this: the TV is a monitor and should always be on the same channel (3, 4, hdmi, or whatever) its actually the box that tunes and the tv always stays on the same channel. so if you change the tv channel you are no longer watching the output of the cable box. USE the remote supplied by your cable provider
11/13/2013 10:07:54 PM • Motorola... • Answered on Nov 13, 2013
0answers
Delay hdmi signal
Be the first to answer 11/8/2013 5:00:50 AM • Motorola... • Posted on Nov 08, 2013Be the first to answer
0answers
My box randomly turns off
same problem here. stb turns off randomly and displays 8888 and locks itself. usually if your press the select button 4 times and turn the stb on again it works but you will have to wait 20 min for it to get the channels or dvr. still no permanent solution though
4/20/2012 7:41:34 PM • Motorola... • Answered on Apr 20, 2012
Motorola Mobility DCH3416 (160 GB) DTV Receiver  Video Recorder Logo
Popular Tags
51 questions posted
Top Motorola Mobility Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Motorola Mobility Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Mobility Televison & Video
Most Popular Question
audio not match video
  • Televison & Video
