20 Most Recent DigitalPersona UareU 4500 Fingerprint Reader Questions & Answers
I just changed my computer.
I don't know the answer but I thought I would mention a computer boffin friend had trouble trying to use stuff intended for 32 bit with a computer running 64 bit Windows.
10/21/2017 9:13:27 PM • DigitalPersona... • Answered on Oct 21, 2017
Offline jamb scanner
i want to update it now
1/28/2014 4:45:08 PM • DigitalPersona... • Answered on Jan 28, 2014
No serial number for neurotechnology activation
how can i get the serial number
12/11/2013 10:31:03 AM • DigitalPersona... • Answered on Dec 11, 2013
2answers
My digitalpersona needs the jamb
moz-screenshot.pngmoz-screenshot-1.pngmoz-screenshot-3.pngYou need our service for that call 08132829820 for your own Biometric License/Offline Software.
Cheers
08132829820
11/26/2013 9:21:36 AM • DigitalPersona... • Answered on Nov 26, 2013
0answers
Download driver fow u.a.u 4500
Question canon DR-2010C scanner which gives error after some times.my system is vista.the error is "The device could not be locked. Check to see that another application isn't using the device -4630". Answer :- change USB cable which is connect with scanner to PC or laptop definitely it will resolve. By:- shyam [email protected] 9210845186
8/2/2013 4:58:43 AM • DigitalPersona... • Answered on Aug 02, 2013
0answers
I want install my u.are.u 4500 finger print reader , i dont heve any dirvers and software
depaning on what u want to use it for, i have four different drivers for u are u 4500 finger print. reply me on my email:[email protected] so i can attach and send to u.
11/28/2012 10:22:45 AM • DigitalPersona... • Answered on Nov 28, 2012
2answers
I installed the fingerprint u. are.u 4500 digital
buy a new boad example mecury or asrock
11/28/2012 9:50:24 AM • DigitalPersona... • Answered on Nov 28, 2012
My jamb biometric is corrupt
Uninstall and re-install it again. That should put you on the right track.
1/2/2012 7:25:25 PM • DigitalPersona... • Answered on Jan 02, 2012
U.are.u. 4500 reads "no scanners connected even
Hello, Did the above solution work? or did u call the Number. am in ***. having the same problem Call the number but available. Pls halla me on this email if u have any solution [email protected]
12/8/2011 2:03:05 PM • DigitalPersona... • Answered on Dec 08, 2011
2answers
Unable to obtain authentication input/output
Check to see if more than 1 biometric scanner is enabled @ device manager>Disabled all leaving only 1 supported finger print scanner enabled.This error is most common if you have on-board or integrated biometric Reader...Try this 1st;still got answers if this doesn't work but it's been proved as remedy for this particular error :) ThanksThe Rule is:Help others without charge :)
8/6/2011 7:32:59 PM • DigitalPersona... • Answered on Aug 06, 2011
Driver cannot detect this device
Does the computer detect the fingerprint reader at all? If it shows up in 'device manager' with a yellow exclamation mark then you have a driver issue. In this case try reinstalling your fingerprint reader driver software. If your device is not being detected at all, try reinstalling your usb drivers from within 'device manager' then plugging your fingerprint reader in once again. If this doesn't solve your problem, you will need to have the reader tested as it is most likely faulty.
Best wishes,
Graemevm
5/3/2011 9:24:43 AM • DigitalPersona... • Answered on May 03, 2011
Jamb site cant recognize my
1. This kind of problem happens when you re-formatted your computer
2. You just install your scanner this year
3. You did not have biometric license installed on your computer, this license makes your scanner authenticated over the internet when you are visiting jamb website, if you are in Nigeria. It also comes with Jamb Biometrics Capture Software, .Net Framework, Java Framework and other software that will make your experience very simple after installing.
4. If, you have the license, then you did not supply the 16 digit security code for the scanner.
The way you out, you need BIOMETRIC LICENSE, if you are operating JAMB BUSINESS.
Hope this help you, if you need more clarification you can email me on biometricmasters2000-jamb at yahoo.com or phone me on 08132829820
4/6/2011 3:32:00 AM • DigitalPersona... • Answered on Apr 06, 2011
Reader is not connected how
You can't thumbprint without scanner but you can be able to thumbprint without problem, if you have the right tool like:
- installing the right driiver of your scanner
- by providing the 16 xter security key
- by having biometric license
All will be history when you have the tool in place.
Do you have your biometric licesne and Jamb biometrics Software
Email us me on [email protected] or call 08132829820
4/6/2011 1:25:19 AM • DigitalPersona... • Answered on Apr 06, 2011
DigitalPersona UareU 4500 Fingerprint Reader Logo
100 questions posted
Top DigitalPersona Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a DigitalPersona Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • DigitalPersona Office Equipment & Supplies
Most Popular Question
download driver fow u u 4500
  • Office Equipment & Supplies
