20 Most Recent Olympus 1GB XD Picture Card (OLYMPUSXD1GB177) for C725760 Ultra Zoom Digital Camera Questions & Answers
Need help
Unfortunately, if the strip is peeled, the card likely has been destroyed. If you caused that to happen, you are likely out of luck. However, If it is new card, I suggest that you contact the vendor who sold it to you and see if they will replace it. Since it is an Olympus Card you might also want to contact Olympus customer support to see what they may suggest. Is it possible that the card may have gotten wet or has been stored in a high-temperature environment? If so, that likely would be looked at as negligence and any warranty would not apply.
9/9/2014 10:25:01 PM • Olympus 1GB XD... • Answered on Sep 09, 2014
7answers
Photo recovery
you can try some photo recovery software. You can seehttp://www.asoftech.com/apr/It tells the steps how to perform photo recovery.If above does not work, you may have to format the memory card (use quick format), and then use above mentioned software to scan again the memory card and recover your files.
6/5/2014 8:42:02 PM • Olympus 1GB XD... • Answered on Jun 05, 2014
How do I veiw my
Once the card is plugged into the card reader, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
7/1/2011 5:09:11 PM • Olympus 1GB XD... • Answered on Jul 01, 2011
Is olympus xd -picture card,type
XD cards are now obsolete memory cards. The cards were developed by Olympus and Fujifilm and released during the summer of 2002. There is now an adapter that allows an SD card to be used in place of the XD card You need to remember that the capacity should not exceed 2 GB or the camera will not be able to accept it. As far as I know cameras accepting XD cards were last produced in 2007, I don't know what specific models however the camera specifications would show what type card it uses.
1/15/2011 8:40:17 PM • Olympus 1GB XD... • Answered on Jan 15, 2011
The zoom of my Olympus digital camera sz-15 has opened by itself, and I tried to close it unsuccessfully.
Take it to a local camera store for professional repair. Or send it direct to Olympus. Camera repair is very specialized and needs to be done in a 'Clean Room'.
10/26/2022 12:45:16 AM • Olympus Cameras • Answered on Oct 26, 2022
I'm looking for an Olympus D-620L SmartMedia card reader
This memory card is known as an 'SM' type of card. Sadly this format is now obsolete and is not in general use like the now common 'SD' type. If you hunt around you can find a general purpose multicard reader that will take various different types of memory card. These are usually cheap to buy and more useful as it can read more than one card type. Something like the link below should do the job. Make sure any you look at have 'SM' or 'Smart Media' in the description. https://www.amazon.co.uk/Hama-00055348-35in1-Multi-Reader/dp/B000IH1W20/ref=sr_1_3?adgrpid=57448009850&gclid=CjwKCAjw9LSSBhBsEiwAKtf0n-_AKryFKznwm__3Ul-GL0TOmO91KadjqGK2V4FtARbJd5m3_VXqUBoCNeoQAvD_BwE&hvadid=311310235362&hvdev=c&hvlocphy=1006688&hvnetw=g&hvqmt=e&hvrand=5544612184098298467&hvtargid=kwd-27614126&hydadcr=28180_1821132&keywords=smart+media+card+adapter&qid=1649235531&sr=8-3
4/7/2022 1:01:12 PM • Olympus Cameras • Answered on Apr 07, 2022
Have a Olympus Camedia C-750. I want to download pictures to my PC via a card reader. Is that possible?
Question edited for clarity. Yes, you just take the xD Card out of the camera and put it into the card reader in the computer. Then open File Explorer and the images will appear as a new drive. Quick Start Guide refers. https://cs.olympus-imaging.jp/en/support/imsg/digicamera/download/manual/zoom/qsg_c750uz_e.pdf ..
2/1/2022 4:26:38 PM • Olympus Cameras • Answered on Feb 01, 2022
My Olympus E-10 is not turning on
There is an internal battery or super capacitor that is supposed to hold the settings in the camera for about 24 hours. It could be dead but it should recharge in a couple of days if you leave the big batteries installed. If it wont turn on after that, you will have to send it in for service.
11/15/2021 6:48:11 PM • Olympus Cameras • Answered on Nov 15, 2021
My Olympus C-4000 zoom will not boot to my imac
Did it do it before? It needs Software and Drivers, it may also need Firmware for your iOS version. I am having difficulty bringing up software for it, even where it is linked. https://www.google.com/search?q=olympus+c+4000+imac+software ./..
10/15/2021 9:39:30 PM • Olympus Cameras • Answered on Oct 15, 2021
I had to by a new memory card to my Olympus Camedia C 750. I just found out that the 1GB I bought, will not work. Is tere any way of make a partion to make the camera accept the card?
Is the card you bought compatible with your camera? Older cameras cannot work with newer versions of memory cards. SD, SDHC,SDXC etc. have different form factors and old model cameras are not compatible with newer versions. If the problem is related to the card, you might like to re-format the card from a computer before inserting it in the camera and then format it again from the camera. Check and verify that before you try other solutions.
7/7/2021 3:45:25 AM • Olympus Cameras • Answered on Jul 07, 2021
My Olympus SP-560UZ shows "battery empty" with new standard (non-rechargeable) batteries. Solutio requested please.
go buy a new battery pack we will not do it for you
5/31/2021 9:32:45 AM • Olympus Cameras • Answered on May 31, 2021
Olympus OM-2 spot/program battery problem: the batteries drain in a couple of shots.
I had a similar issue with an Olympus OM4. It went in for repair but was never resolved. The batteries in my OM1-md last forever! I ended up doing the same remove the batteries after use. I can't remember the configuration, but if the LR44 are two and double stacked, you could use the Lithium equivalent. https://www.batteryequivalents.com/ag13-sg13-lr1154-sr44-303-357-a76-lr44-battery-equivalents.html ..
2/1/2021 12:48:55 AM • Olympus Cameras • Answered on Feb 01, 2021
Where I can find Manual for OLYMPUS ACCURA zoom XB70 camera
Olympus would be a possible source.
11/6/2020 7:59:54 AM • Olympus Cameras • Answered on Nov 06, 2020
Can I get rid of 3c81 error code on my Olympus E-1?
Have you tried using Google to find out what the error code actually means ? Very often, the first step in defining and correcting an error is to find out what has caused it.
6/25/2020 10:31:31 AM • Olympus Cameras • Answered on Jun 25, 2020
3answers
Which camera do you recommend - FujiFilm, Olympus or Sony?
I would recommend Sony for a best film or picture.
6/15/2020 8:46:23 PM • Olympus Cameras • Answered on Jun 15, 2020
HI!my device olympus vn8700pc has memory error what should i do to solve this problem?
This does not appear to be a camera
1/27/2020 1:27:18 AM • Olympus Cameras • Answered on Jan 27, 2020
Olympus 1GB XD Picture Card (OLYMPUSXD1GB177) for  C725760 Ultra Zoom Digital Camera Logo
5 questions posted
Top Olympus Cameras Experts
Steven Wander
Steven Wander
David Shaub
Steve
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Olympus Cameras
  • Olympus Cameras
Most Popular Question
photo recovery
  • Cameras
