20 Most Recent Nikon Digital Camera Coolpix S520 8MP Graphite Black + 4GB Deluxe Accessory Kit (ANIKCPS520GBK2) Questions & Answers
tip
Nikon CoolPix S520
Good day,<br /><br />It sometimes happen that you lose your cameras user manual.<br />This can be very frustrating as you need to look up something, but you can't seem to find a manual anywhere!<br /><br />Well if you follow <a href="http://www.retrevo.com/s/Nikon-S520-Digital-Cameras-review-manual/id/13744ag300/t/1-2/">THIS </a>link you can download your cameras user manual on your computer and thus keep a digital copy handy for all the times you need it.<br /><br />Please let me know if this information was helpful!<br /><br />Kind Regards
How do you download pictures to the computer?
when you plug in the camera with cable to the pc , apear a window, you need just to open the file and search what file had a pictures, selection all pictures that you want to download to the computer and copy and paste the picture to the pc in a new created file
8/8/2010 12:02:20 AM • Nikon Digital... • Answered on Aug 08, 2010
Pictures are white after taking a shot. But when I'm in indoors it's quite normal.
Way, Way Over exposed Gracey. Read the manual for the mystery Nikon Camera and set the camera to Automatic Exposure. Film 'Speed' is measured in ASA Rating, 200 ASA would be standard for outside, 400 ASA for lower light, up to 1200 ASA for very low light like candle light. The higher the ASA Rating, the more grain you will get in an image. In the old days, we used a light meter set to the actual film speed of the roll of film in the camera and the sensor in the light meter told you what to to set the lens aperture and shutter speed to. Now with digital cameras, it is all automatic, or you can choose to go with manual exposure.FULL 'make model (what it is)' in all questions please first 3 words.GoogleNikon (model) manualRead it it LEAST 3 times and at least once with the camera in your lap. Use the camera every day for a week and read it again...
3/27/2024 3:34:09 PM • Nikon Cameras • Answered on Mar 27, 2024
I encounter a problem r07 using my Nikon D3100 with 18-55mm kits lens or my 55-200mm lens. How can I fix this? Thank you.
On Nikon cameras this isn't normally an error code. Have you got a memory card in the camera? Check that it isn't nearly full. r07 common comes up as an information prompt referring to the memory space in the camera. '07' being 7 shots remaining. If the card isn't full try this. Turn the camera off. Remove the battery. Remove the memory card. Leave it like that for at least 15 minutes. Connect the memory card to a computer or a laptop and check you can still look at and move the images that are on there. This is to check the memory card isn't corrupted (developed a fault).
1/28/2024 3:26:09 PM • Nikon Cameras • Answered on Jan 28, 2024
I'm using a Nikon D3100 with a kit lens & my 55-200mm lens. And most of the time I encounter a problem every time I press the shutter button due to r07?
  • The "r07" message on a Nikon camera typically indicates the number of available shots in the camera buffer. It's not an error but rather an informational message. The number "r07" means that there are seven shots available in the camera buffer before it fills up. This is a normal part of the camera's operation and doesn't necessarily indicate a problem. It's more noticeable when you're shooting in continuous or burst mode. If you experience issues beyond this, it's advisable to check your camera settings and consult the camera manual. https://caranddriver.com/
1/26/2024 11:54:11 AM • Nikon Cameras • Answered on Jan 26, 2024
Hey guys, I've got an OLympia Dl000a analog camera with a 50mm lens. can I remove the lens from body & attach it to my nikon d 3200?
it will not fit, but rather than ask why did you not just try it.
1/24/2024 4:08:45 PM • Nikon Cameras • Answered on Jan 24, 2024
Nikon Coolpix s8000 not turning on after charging with provided cords. I've tried charging with both the computer via USB and wall charger.
Try replacing Battery. For further rectification, see page 151 of user manual error messages. S8000_ENnoprint.pdf (nikon-cdn.com)
1/1/2024 2:33:57 PM • Nikon Cameras • Answered on Jan 01, 2024
Nikon 910 Speedlight Flash, how to replace battery cover?
User's Manual
nikon-cdn.com https://cdn-10.nikon-cdn.com > SB-910_EN PDF The SB-910 is a high-performance Speedlight compatible with Nikon Creative. Lighting System (CLS) with a guide number of 34/48 (ISO 100/200, m). (111.5/157.5, ... 136 pages
SB-910 - Nikon ' Download Center
Nikon ' Download Center https://downloadcenter.nikonimglib.com > products Download product manuals. Download product manuals. Title Language Size. User's Manual English 3.53 MB Download. Manual Download Agreement. ..
12/20/2023 7:35:29 PM • Nikon Cameras • Answered on Dec 20, 2023
Nikon Coolpix S570 won't focus in any mode on any object (near or far). No warranty. Is there a way to fix myself?
No unfortunately not. Camera repairs are very complex and require special tools. They are also repaired in a clean room with filtered air by men and women of full cover, coveralls. No fluff or specs on the sensors. Help here including a good answer on JustAnswer. https://www.google.com/search?q=Nikon+Coolpix+S570+won%27t+focus+in+any+mode+on+any+object ..
11/14/2023 6:33:17 PM • Nikon Cameras • Answered on Nov 14, 2023
Error clock R49 error on Nikon D80
this error message is usually caused by a low battery. Here are some steps you can try to fix the issue: Remove the battery from your camera. Fully charge the battery using the Nikon D80 battery charger. Remove the memory card and reset the camera by using the reset option in the menu or by pressing the reset switch on the camera's body, under the connector cover . If the error persists, Nikon recommends waiting for one or two days before sending the camera in for inspection
10/28/2023 6:35:06 AM • Nikon Cameras • Answered on Oct 28, 2023
How do I fix the err low f4.8 on my Nikon d80
From the sites I've looked at al say this about f.... Most of the time, this F Error message is limited to Nikon DLSR cameras. This particular error message appears when the camera is not able to communicate with the lens. To fix F- error message, clean the contacts on the rear of the lens with the help of microfiber cloth and make sure that the lens is locked into its place. If the problem still persists, then try different lenses to identify whether the problem is in the lens or camera. If you are not able to fix it by yourself, then you can take your camera to the service center. I'm not a camera buff but I thought I'd pass this on. other sites too.... https://duckduckgo.com/?q=err+low+f4.8+on+Nikon+d80&t=ffab&atb=v159-1&ia=web Best to you.
8/14/2023 12:00:03 AM • Nikon Cameras • Answered on Aug 14, 2023
My Nikon p900 won't focus on shutter priority
7/26/2023 2:08:25 AM • Nikon Cameras • Answered on Jul 26, 2023
Brand New Nikon Z7ii won't take photos please help!
The fact is won't focus is odd, it should always do that. Issues like this tend to be related to the storage media, and normally falls into two groups. The cards normally have to formatted in the camera and not on a computer. This is because the camera uses its own storage system. The other one is wrong type of card, or too big a card. This page specifies the SD Card type and also says it can only go in slot 2. https://cameratimes.org/best-memory-cards-for-nikon-z7-ii/ and 512GB is the largest card. https://www.google.com/search?q=Nikon+Z7ii+camera+sd+card+maximum+capacity This is for the D7000 but explains the R28 message
I have a d7000 camera. It shows r28 in view finder and i
JustAnswer https://www.justanswer.com > Camera Problems Jul 23, 2018 - The r28 is the count of shots available in the buffer for continuous shooting. You rarely notice it because when the camera takes a shot after ... 1 answer ยท Top answer: Hi, Actually no. The r28 is the count of shots available in the buffer for continous shooting..
5/4/2023 4:06:07 AM • Nikon Cameras • Answered on May 04, 2023
2answers
How do I fix my lens on my Nikon Coolpix B500
Remove the battery and leave it for an hour. Then replace the battery making sure it is fully charged. If that doesn't fix it, you will need a Nikon Service Centre.
Nikon service facilities
Nikon https://imaging.nikon.com > support > facilities Region Facility Phone Argentina Eduardo Udenio y Cia SACIFI Phone: +5411 4648?4294 / 4648?4295 Australia Nikon Australia Pty Ltd. Phone: 1300 401 200 Azerbaijan DIVI Corporation Phone: +994 12 497 31 21 View 91 more rows
3/23/2023 8:14:34 PM • Nikon Cameras • Answered on Mar 23, 2023
How to collimate Nikon Venturer II10x23 6.3 degrees compact binoculars?
Here are the steps to collimate your Nikon Venturer II10x23 6.3 degrees compact binoculars:
1. Adjust the diopter: The diopter adjustment is usually located on the right eyepiece, and it helps to adjust the focus of the image for your right eye. Close your left eye and adjust the focus of the right barrel using the diopter adjustment until the image is clear.
2. Look at a distant object: Choose a distant object, such as a building or tree, and focus on it using both barrels. Keep your eyes on the object while you perform the next step.
3. Adjust the barrel alignment screws: The barrel alignment screws are located on the hinge that connects the two barrels. You may need a small screwdriver to adjust them. Use the screws to adjust the alignment of the barrels until the images in both barrels are aligned. If the image on the right barrel is above and to the right of the image in the left barrel, you need to adjust the right barrel downwards and to the left.
4. Test your binoculars: Once you have adjusted the alignment screws, check the alignment of the barrels again by looking at a distant object. If necessary, make further adjustments until the images are aligned.
5. Repeat the process: Over time, the alignment of your binoculars may shift slightly, so it's a good idea to check the alignment periodically and make adjustments as needed.
3/14/2023 2:20:32 AM • Nikon Cameras • Answered on Mar 14, 2023
Nikon coolpix s210 displays out of memory on screen, cannot take pictures.
Out of memory could mean that your memory card is full and you cannot take any additional pictures until you either replace the card with a new one, or delete or reformat the card you have in it. It could also mean that your card is "locked". Check for the little toggle switch on the side of the card to be sure it is in the "unlocked" position. Or it could mean that you do NOT have a memory card in the camera at all and you're using the very small internal memory your camera comes with (it usually will only hold about 4-5 images. If this is the case, put an external memory card in the camera.
3/6/2023 6:43:56 PM • Nikon Cameras • Answered on Mar 06, 2023
Film camera turns off when I press the shutter button.
There are a few potential reasons why your camera might be turning off when you press the shutter button:
  1. Battery issues: Even if you just replaced the battery, there could be a problem with the connection or the battery itself. Try cleaning the battery contacts and making sure the battery is properly inserted.
  2. Jammed lens: If the lens is jammed or stuck, it could be causing the camera to shut off as a safety measure. Try gently turning the lens to see if it moves freely or if it's stuck.
  3. Faulty circuitry: If there is an issue with the camera's circuitry, it could be causing it to shut off when you press the shutter button. This would likely require professional repair.
It's also possible that the problem is related to the new roll of film you inserted. Make sure the film is properly loaded and that the camera is advancing the film properly. If you continue to experience problems, it may be best to take the camera to a professional for repair or to consider purchasing a new camera.
2/24/2023 10:18:04 PM • Nikon Cameras • Answered on Feb 24, 2023
From where can I buy a Nikon L24 battery door?
nikon or a camera shop in your area
1/23/2023 1:22:49 PM • Nikon Cameras • Answered on Jan 23, 2023
Nikon Digital Camera  Coolpix S520 8MP Graphite Black + 4GB Deluxe Accessory Kit (ANIKCPS520GBK2) Logo
3 questions posted
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
Nikon Cameras
  • Nikon Cameras
Most Popular Question
user manual in english coolpix s520
  • Cameras
