20 Most Recent
Cadet Manufacturing Register Plus RM202 Electric Wall Mounted Panel Heater Questions & Answers
My reset button keeps tripping
Reset button...Is it also a breaker? After they trip a few times they can become weak. Also if possible check all the wiring and make sure all connection are tight and secure.
10/22/2012 12:09:18 AM •
Cadet...
Answered
on Oct 22, 2012
Will not run. Pressing reset button-button does
If the manual-reset limit control has opened the heater circuit due to excessive
operating temperatures, the heater will not work until the manual reset limit
button is pressed. After allowing the unit to cool for at least 10 minutes and
resolving the problem causing the limit to trip; use a narrow object such as
a ball-point pen to access the manual reset button through the lower-right
center section of the heater grill. Press FIRMLY and be sure to listen and feel
for a click, indicating it has been reset.
2/16/2011 11:54:10 PM •
Cadet...
Answered
on Feb 16, 2011
I have a cadet heater
heater shuld have lable telling what max draw is.the breaker protects the wire.short answer is yes, 12/2 will carry 20 amps
1/12/2011 2:09:05 AM •
Cadet...
Answered
on Jan 12, 2011
Domestic hot water works but no hot water to baseboard heat
If its a one story house, the system pressure should be somewhere around 10 to 12 psi. There should be a PRV (pressure reducing valve) on the domestic water line supplying make up water to the boiler. The shut off valve in that line should be in the open position unless the prv leaks through and slowly overpressurizes your system to the point of tripping the pop-off valve. If so, then the manual shut off should be kept closed then opened only to boost the pressure up a bit in the system. It kinda sounds like you are suffering from low system pressure.
If there is a vent or vents in the system, try bleeding them into a coffee cup and you may find it sputtering air/water mixture. Bleed them until you have full water flow and make sure you keep approximately 10 psi in the system.
12/30/2014 12:46:59 AM •
Cadet...
Answered
on Dec 30, 2014
I have a cadet wall heater, the orange light comes on, i have to shut it off and turn it back on. It is blowing heat.
There is a little sensor called a 'flame sensor' that is inserted into the actual flame. Its only job is to complete a grounding circuit on the control board actually through the gas flame... By the description of your problem, it sounds like it either has oxidation on its surface OR the physical connections at the flame sensor itself or where it plugs into the control board have just enough oxidation to imhibit the signal from the flame sensor.
I would suggest calling the service center to have a tech look at it.
12/30/2014 12:36:20 AM •
Cadet...
Answered
on Dec 30, 2014
Hello
How can I disassemble my
Why do you need to dismantle this? Some of these types of cooler do not have replaceable parts inside. They are usually classed as a "Throw away" machine. It is often easier and cheaper to replace it than repair it.
4/9/2024 1:31:04 PM •
Heating &...
Answered
on Apr 09, 2024
