20 Most Recent
Boston Acoustics BA7900 Computer Speakers Questions & Answers
CAN THE BOSTON ACOUSTICS SOUND SYSTEM FOR
Sure if it has RCA or inputs that mate with your TV you can get adapters usually Radio Shack has all of that stuff. I have adapted many a stereo or units to almost all of my TV's love the sounds. Thanks for using FixYa! Splitters are easy to find. John
Can the Boston BA 7900 be converter to use with TV
Yes, but so far I can only get the 2 front speakers and subwoofer to work.
You need a wire that converts a headphone-style jack (like the green one with the Boston speakers) into a red and white AV connection (typical CD/DVD, etc. connection). I've had this connector for a long time and I'm guessing it's under $15. You connect the green Boston speaker connection to the converter end (mine connects to the back end of the headphone-jack (which has a hole for the connection) and the red/white AV connectors to your TV.
I'd been trying to solve the problem too for a long time. Only problem is that I can't get all 5 speakers to work because I think the red/white connector doesn't work with all 5 speakers. I have yet to figure out how to make all 5 work, but the system gives great sound anyway. You will have something like a 5.1 system with your computer speakers, the Boston speakers and subwoofers.
One more issue is that if you connect it directly to the TV, you have to manually turn the Boston speakers on and off.
Boston Acoustics Solo volume knob stopped working altogether. Turning it either way does nothing, no volume number appears. Soft reset doesn't fix it. Any thoughts?
I don't know if you will see this or not, your post was 2 years ago. I have the same problem. My volume is stuck at 24. I have tried soft-reset........among other things. One thread says to turn volume down to 00 then press for 10 seconds. I have no control over the volume, so, yeah, thanks for that fix. I found that I could get the volume down by unplugging it,plugging it back in and sometimes the volume would pop up and I could turn it down one notch. I did it till I got to 00.............thought AHA! My problem is solved! No such luck. When I press the volume at 00 and try to hold it for 10 seconds, after 3-5 seconds it just pops back to the station frequency. I also thought that if I could get into the guts and spray the volume control with tuner-cleaner, it might help. No go.......after taking off the cover, I found a bunch of REALLY delicate looking electrical tapes and wires..........I was scared I would destroy something in an attempt to reach the volume control. I hate to trash this radio, the sound is awesome...............great design on the speaker, NASTY design on the controls. I'd be VERY interested to know if anyone, anywhere, has found a fix for this. I think maybe my next step will be hitting it with a hammer.
