20 Most Recent Sunbeam SLP3310UM Heater Questions & Answers
I think that you should be fine leaving it on as long as it isn't close to any law school books or outlines, as those are known to be combustible. However, if you're worried about damaging anything of value, I would recommend covering the heater with any pea-coats that you may have laying around.
Sunbeam... | Answered on Nov 14, 2013
Could be a problem with the thermostat control
Sunbeam... | Answered on Jan 31, 2012
There a anti-tip switch on it.It needs to be reset by moving the plumer up. Ken's Repair
Sunbeam... | Answered on Sep 14, 2011
did this heater get knock over, sometimes the safety switch gets hung up inside, cheap bi-metal switchs that cycle the heating element burn, power supply, bad plug or recepticle, heck put a high amp relay in and a wall thermostat,it'll probably say made in china on the back
Sunbeam... | Answered on Jan 31, 2010
Blanket, control, or both defective
Sunbeam Heating... | Answered on Aug 23, 2020
then it is time to bin it and get new one no one fixes the wires that break in them
Sunbeam Heating... | Answered on Feb 18, 2020
never cover an electric blanket with anything. use it as a blanket above you only. read the instructions please for your safety
Sunbeam Heating... | Answered on Dec 22, 2019
Generally means u have a bad connection at the wall or at the control module. Disconnect everywhere u can and reconnect
Sunbeam Heating... | Answered on Sep 09, 2019
Try unplugging the power cord from the wall socket and check that the connection to the blanket is good and not loose. Then plug back into the wall socket and switch on. If error still occurs then there may be a problem with the blanket.
Sunbeam Heating... | Answered on May 17, 2019
Probably means the pad has failed and will have to be replaced
Sunbeam Heating... | Answered on Feb 05, 2019
If you have the same heater i do then in between the elements at the bottom there is a safety swith that bends when it heats up and breaks the connection Dont mess with it plugged in it will shock the hell out of you but if you bend it down it wont be able to lift off the circut and will stay running untill you turn it off
Sunbeam Heating... | Answered on Dec 29, 2018
Wires probably damaged inside. Be carefull, I had one cought on fire. Dont like this things ever since
Sunbeam Heating... | Answered on Dec 28, 2018
unplug replug blanket to control connectors plug back in
this will continue to happen on these blankets you will have to reset these blankets again and again (chinese junk)
Sunbeam Heating... | Answered on Dec 22, 2018
http://www.electricblanketinstitute.com/blanket-or-comforter-on-top-of-electric-blanket.html
Sunbeam Heating... | Answered on Dec 10, 2018
TIME TO CHUCK IT AND BUY NEW
Sunbeam Heating... | Answered on Nov 21, 2018
Sunbeam SLP3310UM Heater Logo
Popular Tags
12 questions posted
Top Sunbeam Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Sunbeam Heating & Cooling
Most Popular Question
sunbeam slp3310 electric heater
  • Heating & Cooling
