20 Most Recent Amana D565M Dehumidifier Questions & Answers
The drain tube, that is supposed to drain the water in to the bucket may be partially clogged.
To solve the problem, follow the instructions below.
Turn the unit OFF and unplug it.
Remove the water collection bucket and look up inside the bucket holder cavity. You will see either a drain hole or small tubing that drains the water into the bucket. Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reinstall the bucket, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor it for any leakage.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers
I hope this helped you to troubleshoot and solve the problem.
Amana D565M... | Answered on Jul 19, 2011
The humidity sensor or the humidistat is probably the problem...
Replacing these can correct the problem, but may cost more then the dehumidifier is worth...
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Amana D565M... | Answered on May 10, 2010
hi there.
this is all i could find.
go to this link and it might help you out.
AMANA DEHUMIDIFIER model D945E WILL NOT DRAIN ANY WATER Google Search
Amana... | Answered on Nov 06, 2017
I encountered a similar problem (using the bucket, but still getting water leaking onto the floor) with my 970E-E. The problem is a design flaw. If the bucket is not firmly pressed into the dehumidifier, there is a slight air gap between the bucket and the dehumidifier on the left side. Within the gap, warm moist environmental air cools. Water condenses in the gap and pools up at the bottom of the bucket shelf, eventually spilling over onto the floor. You can check and see if this is your problem by pulling out the bucket and inspecting for droplets along the left side of the bucket shelf. My solution was the bungie the bucket into the shelf firmly so that there is no air gap.
Amana... | Answered on Jun 27, 2017
Amana D565M Dehumidifier Logo
7 questions posted
Top Amana Dehumidifiers Experts
NOEL
NOEL
Tom Chichester
Terry
Terry
Are you an Amana Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
Amana Dehumidifiers
  • Amana Dehumidifiers
Most Popular Question
dehunidifier leaking water all over
  • Dehumidifiers
