20 Most Recent
Vicks V745A 1 Gallon Humidifier Questions & Answers
It's just not working..no mineral
At only two months old, it's still under warranty for either repair or replacement. Best thing to do, is contact the manufacturer and have your Proof of Purchase handy.
My humidifier is not working.
There is probably a calcium buildup in the lines from the tank to the humidifier. You will need to take it apart to lean it. 50/50 White Vinegar should do the trick, Then flush the system with clean water, before using it as a humidifier again. In the future try using Bottled Spring Water or Distilled Water instead of tap water. Especially if your source of water is a well.
My electric bill soared last month and this
The humidistst sounds like it is not regulating the humidty. The system probably is not shuttung off. Depending upon the humidistst setting.Check wiring from the humidistat and humidifier. Try to locate a installation mqanual fir the unit via the internet.
Vicks hot steam cord gets really hot
My cord is also getting very hot after being plugged in for just a few minutes. Is there a cause for concern here? It's not even a year old, bought in January of 2022.
8/29/2022 11:38:59 PM •
Vicks...
Answered
on Aug 29, 2022
Why does my humidifier make the floor all wet
You may be over filling the unit. Take the refillable water tank out and with the power removed try to remove all the extra water where the tank goes. check for anything that looks cracked inside the unit the best you can. If the tank is seating properly it should not leak. If it is filled properly it should not leak.
2/22/2022 6:21:36 PM •
Vicks...
Answered
on Feb 22, 2022
