20 Most Recent
Sunbeam SCA052MWC1 Air Conditioner Questions & Answers
Air conditioner will not cool bedroom
It sounds like the unit is failing to refrigerate, the cracking noise is most likely a compressor fault (trying to run) it may be stalled or have suffered a motor failure. The noise may also be an electrical short but unlikely as this would trip the safety trips in the house.
If you still have warranty i would return it or demand a HVAC engineer to inspect and repair faults.
all the best
7/16/2014 4:16:39 PM •
Sunbeam...
Answered
on Jul 16, 2014
I am looking for a
If you try with electronic spares shop, you will be able to get some replacement for the knob. A universal type can always be fitted and you can source this even from the gas/oven spare parts stores.
Also if you check with any AC repair shops the knob can easily be salvaged from an old non working set. I am sure you can find one from any of these shops.
Hope my advice helps. Good day
8/17/2010 6:51:52 AM •
Sunbeam...
Answered
on Aug 17, 2010
Sunbeam BL0750 electric blanket green light blinking
Sure, here are a few suggestions on where to find a replacement controller for your Sunbeam BL0750 electric blanket:
* **Sunbeam customer service:** You can contact Sunbeam customer service directly and they may be able to help you find a replacement controller. Their contact information is available on their website.
[Image of Sunbeam customer service website]
* **Online retailers:** There are a number of online retailers that sell replacement controllers for Sunbeam electric blankets. A quick search should turn up a few options.
* **Local hardware stores:** Some local hardware stores may also carry replacement controllers for Sunbeam electric blankets. It's worth checking with your local store to see if they have any in stock.
Once you've found a replacement controller, you can either install it yourself or have a professional do it for you. If you're not comfortable installing the controller yourself, you can take your blanket to a qualified electrician or repair shop.
Here are some additional tips for troubleshooting your Sunbeam BL0750 electric blanket:
* Check the power cord to make sure it's plugged in securely.
* Try using a different outlet.
* Check the fuse or circuit breaker to make sure it's not tripped.
* If you've tried all of these things and the blanket still doesn't work, you may need to replace the controller.
I hope this helps!
Sunbeam heater SQH310 keeps shutting off when it is on 2, what do I do?
If you have the same heater i do then in between the elements at the bottom there is a safety swith that bends when it heats up and breaks the connection Dont mess with it plugged in it will shock the hell out of you but if you bend it down it wont be able to lift off the circut and will stay running untill you turn it off
Just need to know if
Lower temperature will keep the room cooler. For efficiency sake, lower the temperature gradually to
68 degrees.
Hope this helped you. Thanks for choosing FixYa.
My sunbeam heating pad remote is flashing the letter f
My sunbeam XL heating pad started blinking and I couldn’t figure it out. I Unplugged a couple of times and still it kept flashing. After hours of reading post, I did what wpart suggested and now it works normal again..... I kept pushing th on off button while plugged in, I unplugged it while still hitting the on off button, I plugged it back in while still hitting the on off button annnddddd drum roll please!!!!!! It started working properly! Thanks wpart, your the MVP and award goes to you!
