20 Most Recent Olympus Stylus 7030 Digital Camera Questions & Answers
Black screen
lens block faulty
10/13/2014 2:41:48 PM • Olympus Stylus... • Answered on Oct 13, 2014
Canon battery
Without testing the camera my guess is the the camera is damaged by reversing the charge connection and may not be worth repairing.If it was me I would putting my money towards a new camera..
5/9/2013 8:52:50 AM • Olympus Stylus... • Answered on May 09, 2013
My olympus stylus 7030 isn't showing any images on the screen. I can take pictures, but I can't see them. I also can't pull up the menu to make any changes as the screen isn't workin
Hello, Are you sure you have not turned off the LCD display by mistake. Check your settings.Best Regards, Russell
1/24/2013 2:23:49 AM • Olympus Stylus... • Answered on Jan 24, 2013
Olympus stylus 7030. No zoom function when using video setting?
The optical zoom will not work while recording video with sound. To use the optical zoom, turn the sound off. See pages 16 and 33 of this manual.
1/7/2013 2:05:56 AM • Olympus Stylus... • Answered on Jan 07, 2013
My Olympus Stylus 7030 won't focus and shuts off when I try to zoom.
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
7/30/2012 11:48:40 AM • Olympus Stylus... • Answered on Jul 30, 2012
When turn on, two black do appears on the monitor
Moisture got into your camera. Dry it may work or replace lcd screen if available from ebay parts camera.
7/16/2012 7:24:53 AM • Olympus Stylus... • Answered on Jul 16, 2012
Camera powers down right after it turns on
Change/recharge the batteries. Also could have a lens jam.
6/19/2012 1:21:33 PM • Olympus Stylus... • Answered on Jun 19, 2012
Flashing blinking lights
Check the battery.
4/24/2012 12:23:04 AM • Olympus Stylus... • Answered on Apr 24, 2012
Try to download pictures to computer and says no connection
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
2/20/2012 5:41:51 PM • Olympus Stylus... • Answered on Feb 20, 2012
Olympus stylus 7030 flash problem
It could be circuit, capacitor or the flash tube itself? Digital cameras are so cheap now that buy a new one is a good choice.
2/16/2012 12:35:29 PM • Olympus Stylus... • Answered on Feb 16, 2012
How to remove the write protect
Write protect on memory card, should be a small slider on memory card to change lock to unlock.
2/8/2012 7:18:23 AM • Olympus Stylus... • Answered on Feb 08, 2012
The camera displayed "IN WRITE PROTECT"
Remove the SD memory card and with the contacts up and facing the back, locate the small tab on the right hand edge. Slide it from the LOCK position to the UNLOCK position. Reinsert the card and try again.Good luck!
1/26/2012 10:30:23 PM • Olympus Stylus... • Answered on Jan 26, 2012
I have a Olympus stylus 7030 and I can't get
You have two choices: take advantage of the warranty or this:
Copy and paste this website into your browser for solutions:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
11/4/2011 9:15:28 PM • Olympus Stylus... • Answered on Nov 04, 2011
Camera wont focus
If it recently sustained a drop or other impact, the lens mech is damaged. With the lens out, visually inspect it to see if it may be slightly crooked or askew. If so, gently try to "pop"it back into alignment. If not, sand or other debris may be caught in the mechanism. While the camera is turning on and the lens is extending, gingerly (but firmly) tap the cameras bottom against a counter or other hard surface. This will often let the debris work its way out.
Let me know if this works or not.
10/16/2011 1:18:22 PM • Olympus Stylus... • Answered on Oct 16, 2011
Olympus Stylus 7030 Digital Camera Logo
52 questions posted
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Stylus Olympus
  • Stylus Olympus
Most Popular Question
cannot collapse lens
  • Cameras
