20 Most Recent
Samsung Digimax NV100HD Digital Camera Questions & Answers
How do I use the focus
be sure your lense and autofocus sensors are clean first thing.. then push the take picture button half way and it will autofocus. Pressing hte take picture button fully then will snap the picture.
Usb usb data transfer cable
Have you considered NOT connecting your camera to your computer?The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa (
http://picasa.google.com ).
How to use self timer Canon 2000 IS
I'm assuming you mean the IXY 2000 IS.Press cursor-down (marked with a one-handed clock) to bring up the shutter release menu, then use cursor-up/down to select the desired self-timer mode. Start the self-timer by pressing the shutter release button as usual.The IXY 2000 IS is called the SD950 IS in some parts of the world. You may download the SD950 IS manual
from here. The self-timer instructions begin on page 73.
Can i install samsung d760 to windows xp?
You don't need a driver.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
