20 Most Recent Kodak EasyShare CD14 Digital Camera Questions & Answers
The CD14 is compatible with SDHC cards up to 32GB in size.
Kodak EasyShare... | Answered on Apr 14, 2020
Sorry, you can't. The CD14 is designed to store images and videos to memory, not to stream live video to another device.
Kodak EasyShare... | Answered on Mar 19, 2018
You could try the actual Kodak site, but if the camera has been immersed in water it is probably ruined, and installing firmware is unlikely to help.
Kodak EasyShare... | Answered on Jul 22, 2017
Try Googling your camera make/model. I did this as an example. I was able to download the PDF manual for free.
Hope this helps. Mike
[PDF] KODAK EASYSHARE CD82 Digital Camera resources.kodak.com/support/pdf/en/manuals/urg01070/CD82_xUG_GLB...
KODAK EASYSHARE CD82 Digital Camera Extended user guide www.kodak.com For interactive tutorials: ... Use power-saving features (see Using the Setup tab, page 28).
Kodak EasyShare... | Answered on Dec 13, 2015
yes
Kodak EasyShare... | Answered on May 25, 2014
This problem happens because oflong time no using/ Dust or Lens guide pin damaged. If the lens guide pindamage then there is no chance for repairing . Only solution is replacing thelens. For the solution you need to follow the steps.1. Turn off the camera and remove the memory card and clean theexternal body of the camera and make sure in place of the lens there is no dustor damaged sign.2. Now turn on the camera without memory card & make sure thebattery are fully charged.3. If the lens not moving then give a little shake or thrust by hand( carefully very slow) and then wait for a moment. If no changes then turn onthe camera and give a little twist an anti clock side and leave for few second.It is risky ( Do it slowly at your own risk)4. If nothing change then reset the camera setting from the menuoption.After following all steps, if thecamera does not start working then you need to visit service center forreplacing the Lens or Repairing. But before repairing ask service center theapprox cost. if they told you to replacing the lens then do not do that.Because a new lens & service charge cost you near about a new camera price.So best is buy a new camera. If you have any more questions ask me I fell happyto answer your question. Thank you.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html - - - Doit your self lens fix
Kodak EasyShare... | Answered on Jun 29, 2013
Remove the batteries and clean off the battery fluid from inside the camera. If you don't the battery contacts will corrode and it will not make contact with the new batteries and the camera will not work.
If you do not intend to use the camera for a long time then remove the batteries and only insert them when you want to use the camera. this will stop a battery corroding in your camera.
Kodak EasyShare... | Answered on Jan 31, 2013
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as the free Picasa.
Kodak EasyShare... | Answered on Dec 18, 2012
Press the MENU button. Use cursor-left/right to select Setup, then use cursor-up/down to select "Date & Time". Use cursor-left/right to move between the fields, cursor-up/down to change them. Press the OK button when done.
Kodak EasyShare... | Answered on Apr 09, 2012
The best bet is a card reader.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as iPhoto on Mac or Windows Photo Gallery on Windows.
Kodak EasyShare... | Answered on Apr 08, 2012
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Kodak EasyShare... | Answered on Aug 15, 2011
Check the Kodak web site for software and downloads to your computer. I did this myself and it cost me nothing. Do you have a mnanual for the camer? if not get one from Kodak.
Kodak EasyShare... | Answered on Jun 28, 2011
1. Maybe battery is dying
2. If its suplied try to take photos while connecting ac adapter
Kodak EasyShare... | Answered on Jun 07, 2011
If you have been downloading the pictures from the camera to a specific folder, this could cause it to happen. For example, if you have a picture titled IMG0021 and you copied it to the folder on your computer, and deleted it from the memory of the camera, there might be a new replacement for the file depending on your camera settings. That is, since IMG0021 is no longer available, your camera might automatically name another recent picture IMG0021 thereby causing conflicts between them.
The best way to solve this problem if you want to keep all your files in one folder is by renaming your pictures or setting the camera to name them in another method( this function is not always available in all camera models).
Also, another step you can take is by copying them to another folder and see if it copies. If it doesn't copy and gives the same error, then you might have to seek help from an engineer as the computer maybe having problems or conflicts working with your camera.
Hope this was helpful? Please comment for more information and thank you for using FixYa.
Kodak EasyShare... | Answered on Jun 01, 2011
Kodak EasyShare CD14 Digital Camera Logo
36 questions posted
Top Kodak Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
