20 Most Recent
Polaroid t1232 Digital Camera Questions & Answers
Polaroid digicam no flash
If the camera is working normal and the flash is not turned off then the camera will need repairs, the flash unit is not a user fix item.
Back screen is cracked .
Is
The screen can be replaced at times however it's quite costly (I've seen it cost up to $400 before). Honestly you're better off getting a new camera unfortunately.
Green light flashing on Polaroid iE 6035
The green light flashing on your Polaroid iE 6035 camera typically indicates that the camera is in standby mode or that it is charging. If the camera is not charging, it could be a sign of a problem with the battery or charging mechanism. If the green light continues to flash even after charging, it may be necessary to take the camera to a professional for repair or to have the battery replaced. Before seeking professional help, you can also try resetting the camera or removing and reinserting the battery to see if that resolves the issue.
