20 Most Recent Eureka AirSpeed One Turbo Bagless Upright Vacuum with Turbo Nozzle, AS2011A Questions & Answers
2answers
Eureka vacuum blowing dust into the air
Check the leak (where the dust come from); maybe you need to tighten or reseat one or more part in that area.
11/20/2016 7:54:48 PM • Eureka AirSpeed... • Answered on Nov 20, 2016
My Eureka Mighty Mite 3670 vacuum turns on but does not suction or blow.
Nothing you have described should cause it to fail. Claim on the one year warranty irrespective of how long you have had it. What happens if you remove the hoses and turn the machine on? Does it suck from the hole in the body where the hose attaches? If it doesn't then the disc that is attached to the motor has sheared off the motor spindle. Was the stone in the bag, or did it punch a hole in the bag and meet the motor? https://www.google.com/search?q=Eureka+Mighty+Mite+3670+warranty ..
12/4/2022 4:33:31 PM • Eureka Vacuums • Answered Yesterday
I bought a used Eureka Hotshot steamer. It gets warm , but no steam when I push the button. It also had whiteish water come out. Should I just throw it out
based on the price of a new one and no repair parts available, personally I would throw it away and mark it it up as lesson learned.
10/29/2022 2:27:16 PM • Eureka Vacuums • Answered on Oct 29, 2022
4answers
Eureka 2089 A - needs a replacement on/off switch. The company says they no longer make the part. Any ideas?
If you have the time allied electronics has extensive electronic parts or if you have a local electronics shop. Many years had an old Eureka Canister switch failed and I found a toggle switch that fit perfectly . It lasted another 7 years.
8/19/2022 9:03:55 AM • Eureka Vacuums • Answered on Aug 19, 2022
Eureka NEC160 Vacuum Cleaner battery charger output voltage please?
Question edited to clarity. Question moved to Eureka Vacuums from Health and Beauty. 25 Volts for similar models. Test it with a meter, it is more likely the battery has failed. https://www.amazon.ca/Adapter-Replacement-MC2508A-NEC-124A-CC170001A/dp/B081Z9DJZR ..
1/4/2022 6:25:44 PM • Eureka Vacuums • Answered on Jan 04, 2022
Eureka vacuum belt model number 3271
you can check this link. I guess this should be helpful. If not, check for the related products underneath.
12/9/2021 7:28:33 AM • Eureka Vacuums • Answered on Dec 09, 2021
I have a Eureka The Boss superlite upright vacuum Model405 I know...it's old..LOL. I was vacuuming and it just shut down and I was wondering if there was a reset button somewhere. Thanks
I am not sure about your "Boss", but a lot of vacuums have thermal cut-off switches built into the circuit so if the machine overheats from things like clogged filters/hoses the switch kicks in and kills power. You usually can NOT reset it manually ... you just have to wait until the machine cools down.
8/21/2021 4:19:20 PM • Eureka Vacuums • Answered on Aug 21, 2021
My Eureka boss vacuum does not power until handle is pulled down.
That sounds like a design feature and it the same as my Dyson. It stops you leaving it in one place with the brush turning. Google Eureka (model) Manual (or Review)
7/11/2021 6:09:07 PM • Eureka Vacuums • Answered on Jul 11, 2021
Eureka 4870 brush roller stops spinning under any pressure
Check belt
3/21/2021 2:41:33 PM • Eureka Vacuums • Answered on Mar 21, 2021
2answers
Eureka vacuum model#2961 Won't start???
Well documented issue, overheating, melted cheap wiring, cheap burned out switches made in China, a Dyson, it is not! Had exactly the same problem with my upright Eureka Model 5893 bagless. Eventually, the handle would get hot, and finally it just quit. When handle was disassembled, the wires were melted and it was toast. Ordered a switch after talking to several repair men. Talked to Eureka, too, and they were absolutely no help. Cheap wiring and switch made in China. Good luck trying to find a switch. vacuum-depot.com has switches, so you might try there, but make sure you get the 3-prong switch (same switch used on Eureka's Genesis). It is Part #27871. And lots more https://www.google.com/search?q=Eureka+vacuum+model%232961+Won%27t+start
3/20/2021 6:20:15 PM • Eureka Vacuums • Answered on Mar 20, 2021
Eureka "The Boss" vacuum just quit. No power at all.
Lack of power, a bad power cord, failed drive motor or broken wires in the vacuum hose can prevent the vacuum cleaner from starting. Make sure the electrical outlet that you're using for the vacuum cleaner works. Try using a different outlet if you suspect that the outlet you're using is dead. https://www.searspartsdirect.com/diy/symptom/vacuum-cleaner-repair/1234581/won-t-turn-on/vac1000
5/11/2020 11:23:25 AM • Eureka Vacuums • Answered on May 11, 2020
I'm looking for a replacement hose for my eureka steam cleaner...
https://www.youtube.com/watch?v=cGqQ5MfNomA
3/21/2020 9:58:23 AM • Eureka Vacuums • Answered on Mar 21, 2020
Eureka AirSpeed One Turbo Bagless Upright Vacuum with Turbo Nozzle, AS2011A Logo
Popular Tags
6 questions posted
Top Eureka Vacuums Experts
David Shaub
Steve
Mike
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Eureka Vacuums
  • Eureka Vacuums
Most Popular Question
eureka vacuum blowing dust into air
  • Vacuums
