20 Most Recent
Select Brands 20012 500°F Heating Element Electric Kettle Questions & Answers
WATER HEATER ELEMENT IS NOT WORKING NEED TO
is there one or two,, turn off power drain it down, use the water heater element wrench remove the wires and the element, install new element snug it tight, start filling the water heater while it is filling reinstall the wires, turn on a hot side faucet only let the air out, wait till you have a full flow of water out of the faucet then turn the power back on to the unit, the thermostat should beat 120 degrees,
Electric oven
CODE 7 IS POWER CODE FLIP BREAKER OFF COUNT TO FIVE TURN ON BREAKER THEN RESET CLOCK IF THAT DONT HELP THEN YOU CHECK WIRES AND PLUG TO MAKE SHURE ALL ARE CONNECTED YOU SHOULD HAVE TWO POWER LEADS AND ONE GROUND IF THEY ARE OKAY THEN YOU HAVE ROACHES IN OR ON ELECTRONICS CARD TAKE IT APART AND CLEAN IT YOURSELF OR HAVE SOMEONE WHO KNOWS WHAT THEY ARE DOING CLEAN IT
Maplin N20FR - damp test meter. I have no
N20FR - Used to measure the moisture level in sawn timber (also cardboard, paper) 6 to 44% on the left hand scale and hardened materials (plaster, concrete and mortar) 0.2 to 2.0% on the right hand scale
4/14/2024 9:12:34 PM •
Kitchen...
Answered
on Apr 14, 2024
