20 Most Recent Toshiba TEC B-452 Thermal Label Printer Questions & Answers
I have a toshiba estudio 452 when i want to print it shows E550 but there is no paper in the paper feed area , and I checked it several times
Toshiba TEC... | Answered on Mar 30, 2016
Download driver from seagullscientific and reinstall GBAR
As far as I can remember the windows driver used was from seagull scientific.
www.bartenderbarcodesoftware.com
Toshiba TEC... | Answered on Sep 11, 2014
1000 / 50 + 2 that is approximately 18
Toshiba TEC... | Answered on Sep 10, 2014
Check the fonts used.
Probably a driver problem
change the heat value and the speed value or you may have the wrong ribbon
Try alcohol and a soft cloth or cotton.
But I'm afraid you'll have to change the print head.
Toshiba TEC... | Answered on Jun 10, 2014
First of all check that the ribbon core is correctly placed with the notches fitting on the Green wheels. If th ribbon coe is not secured the wheel will not turn and no ribbon will be detected. If your core is too short and with no notches, you'll have to glue a pice from another core an create a notch.
Check that it is correctly selected or change the sensors
Toshiba TEC... | Answered on Jan 14, 2014
Either you recllibrate the sensors or no other solution exists
Use bartender ultra light available with each printer will do the trick
Get the drver from your toshiba dealer with a more recent bartender 10.1
Send the correct length to the printer.
Use a windows driver to sent a test page at the correct size and dectection
Check the detection and the label size.
Use no detection if it's continuous media or transmissive or black mark but if you use detection sensor check that the size is correct.
Check that you are not in direct thermal mode and if the roll is correctly placed on the supports. If the roll is not meant for this printer then you have this error
Toshiba TEC... | Answered on Dec 09, 2013
You have to callibrate the sensors and check your settings in the driver
I have the manuals
check that you have chosen the correct detection (Trasmissive)
This looks like you are using continuous paper.
probably dots broken on the print head
Swtch on with pause key depressed and wait for the power and online leds blinks and error led off.
To cahnge from thertransfer or direct printing mode depress feed and pause spontaneoulsy.
By depresing feed the self test is printed
Toshiba TEC B-452 Thermal Label Printer Logo
33 questions posted
Top Toshiba TEC Office Equipment & Supplies Experts
CheckitRight
CheckitRight
matt
matt
ANTISPAMMER
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba TEC Office Equipment & Supplies
Most Popular Question
many 50mm label in 1 meter wax
  • Office Equipment & Supplies
