20 Most Recent R.A.M. Computers LASCO-5540 Ceramic Radiator Heater Questions & Answers
I have the same heater and when that happens just unplug it for about 15 minutes and plug it back in and it should work fine. It only does this for me when I am using a extension cord or a power strip. It needs a dedicated power supply (wall outlet) with nothing else attached. If you must use a extension cord I have found that the heavy gauge orange power cord is the only one that does not overheat and causes the heater to shut off. The heater comes with a 3 year warranty, the longest warranty I have ever seen with a heater.
R.A.M. Computers... | Answered on Feb 22, 2016
You are sure you have power at the plug? If so it sounds like the internal circuit breaker tripped or the switch is bad. Either way, throw the heater away, they are not designed to be field repaired, sorry.
R.A.M. Computers... | Answered on Dec 16, 2008
Sasco Small Appliance Service Company Ltd. 420-28 Street NE CalgaryAlbertaT2A 6T3 Canada 403 235 1020403 273 9714
R.A.M. Computers... | Answered on Sep 24, 2007
Did you rise the temperature on the thermostat higher than room temperature?
Check the igniter ( if it's a gas furnace) to see if it glows when you try to start the furnace, if it doesn't, replace it, that is if you have it wired right.
Good luck
Heating &... | Answered 4 hours ago
. you never said what appliance this is make model nat gas lpg ??
Heating &... | Answered 12 hours ago
Code for fujiaire 090
Heating &... | Answered Yesterday
I had exactly the same problem as you describe with my Logic Combi 30 boiler. I phoned them, and they said it was simply to indicate that the wireless thermostat (that little white thing that came with the boiler and tells you the temperature etc.) wasn't picking up a signal from the boiler. It's NOT dangerous, and will almost certainly just be temporary; and even if it's not temporary, it's still NOT dangerous. So no need to worry -- it's not important!
Heating &... | Answered 2 days ago
https://www.fix.com/repair/appliance/air-conditioner/does-not-turn-on/
Heating &... | Answered 3 days ago
I would look on the potterton /baxi wedsite or ask there technical line
check for power at gas valve.
We need to know the make and model and what you mean exactly. Details are important.
Heating &... | Answered on Oct 17, 2020
Either the pilot flame is weak and not reaching the thermocouple bulb, the bulb is misaligned and isn't being heated or the thermocouple is faulty.
Heating &... | Answered on Oct 16, 2020
If you are looking for a replacing remote control for a Warmlite WL45033N fireplace, then I will recommend checking DIY; they are offering an Electric fire replacement remote control.
Heating &... | Answered on Oct 14, 2020
Work on your diagnostic skills and HVAC principles. Go beyond changing parts. Learn controls systems. Join a union is your easiest bet though. Hit up your local chapter.
Heating &... | Answered on Oct 12, 2020
Do you see the tag like in the manual below and across from series is the model. under specifications
Hope this helps
https://www.ghpgroupinc.com/manuals/Wall%20Heater/Wall%20Heater%20Manual%202018_IR30NMDG-1.pdf
Heating &... | Answered on Oct 07, 2020
R.A.M. Computers LASCO-5540 Ceramic Radiator Heater Logo
4 questions posted
Top R.A.M. Computers Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Are you a R.A.M. Computers Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • R.A.M. Computers Heating & Cooling
Most Popular Question
having problem heater bought
  • Heating & Cooling
