20 Most Recent Paradigm Monitor 9 Speaker Questions & Answers
2answers
Tweeters no out put
cang your pollarty
1/17/2015 2:57:19 PM • Paradigm Monitor... • Answered on Jan 17, 2015
How to Replace a paradigm monitor 9 v6 driver
Are you having trouble removing the driver? Just remove it and replace, keeping track of where the positive (red) terminal is and what cable is connected there. The part number should be printed on the back of the magnet.
1/17/2015 2:55:42 PM • Paradigm Monitor... • Answered on Jan 17, 2015
Paradigm Monitor 9 v4 tweeter not working.
speaker is must likely blown. check to see if another tweeter works at that connection.
11/19/2014 6:10:02 PM • Paradigm Monitor... • Answered on Nov 19, 2014
Paradigm monitor 9 v.5
The more power the better as far as amplifiers go, underpowering speakers causes clipping and burns up voice coils. Having a high power reserve means you have higher headroom for transients, with more power the amp will be able to handle transients better and will not be running at full output all the time in order to get desired volume levels, hence more headroom.
If you want to go with quality go with components, a seperate dedicated high quality amplifier such as a haffler, crest, etc., amps you find powering monitors in studios. It all depends what you want.
8/6/2008 7:30:08 PM • Paradigm Monitor... • Answered on Aug 06, 2008
What fuse does a Paradigm dsp-3100 use ??
did u get ur answer to your fuse problem
6/9/2019 6:00:59 PM • Paradigm Audio... • Answered on Jun 09, 2019
What size fuse does a Paradigm dsp-3100 take ??
100-240v 1.6amp is what it says.
6/9/2019 7:57:51 AM • Paradigm Audio... • Answered on Jun 09, 2019
My speakers sound flat with no highs at all
I am trying to work out if you have damaged the speakers and amp too. Have you tried a pair of headphones on the amp? If they sound ok then your amp is fine. Assuming it is, then speakers have what's called crossover units in side each of them. This splits the sound into three parts. Bass, midrange, treble. The bass is handled by the woofer's, the midrange by a middle sized speaker or or it's combined with a tweeter, which of course handles the treble. Connecting a 1.5 volt battery across any of the individual speakers will cause it to pop if working. If the speaker then is not getting sound then the crossover unit is to blame. When you look at the crossover unit, it will have coils and capacitors (non polarised) on it. The bigger ones deal with the bass and the smaller ones treble. If you find a fault say on the crossover of the speaker, for example no treble comes out of it. Then start by replacing the capacitors. Use the same value as on the capacitor and remember they fit any way round.
4/16/2017 1:30:20 AM • Paradigm Audio... • Answered on Apr 16, 2017
How do I hook up the receiver to the subwoofer to the tv
Here's the Owner's manual -> https://docs.google.com/viewer?url=https%3A%2F%2Fwww.paradigm.com%2Fdownloads%2FOM-100.pdf. There are many ways to connect the system depending on your receiver's outputs and the speakers. Usually, the TV L/R output connects to one of the receiver's inputs. The receiver's preamp sub output goes to the powered subwoofer. The receiver's FL/C/FR/SL/SR/RL/RR speaker outputs go to the respective speakers.
3/3/2017 2:52:17 PM • Paradigm Audio... • Answered on Mar 03, 2017
How do I disassemble Paradigm PDR-12?
Look for any screws that are holding it together and remove them.
1/13/2017 5:21:56 PM • Paradigm Audio... • Answered on Jan 13, 2017
Low sound coming from speakers, volume needs to be at 55 in order to hear anything. how can i fix it
Try using a "cheater" plug at the electrical outlet to the wall for your front end equipment. It does a "ground lift". If your equipment plug is 3-prong, a cheater plug will make it a 2-prong.
11/8/2016 10:30:38 PM • Paradigm Audio... • Answered on Nov 08, 2016
What would cause paradigm sub12 not to power on
The inside of a subwoofer isn't really a great place to put an amplifier, that that is what you have. These things do go bad from time to time. You may be able to get it repaired, or you could replace the amp. You're looking for a "plate amp". Parts Express has a good selection: Subwoofer Plate Amplifiers
10/14/2015 9:39:44 PM • Paradigm Audio... • Answered on Oct 14, 2015
How do I stop my Paradigm sub from humming and "burping?"
The amplifier that powers the sub is the source of your problems. Sounds like some power supply filter capacitors are failing.
12/31/2014 5:03:52 PM • Paradigm Audio... • Answered on Dec 31, 2014
0answers
Paradigm Monitor 9 Speaker Logo
Popular Tags
10 questions posted
Top Paradigm Audio Players & Recorders Experts
Ekse
 Grubhead
Grubhead
Are you a Paradigm Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Paradigm Audio Players & Recorders
Most Popular Question
paradigm monitor 9 v 5
  • Audio Players & Recorders
