20 Most Recent Rustoleum Rust-Oleum Epoxy Shield Professional Semi-gloss Dunes Tan Floor Coating Kit 203846 Questions & Answers
You're probably already done with your project by now, but you should wait at least 24 hours, lightly sand, and wipe surface with acetone and a microfiber towel before applying a second coat.
Rustoleum... | Answered on Mar 17, 2015
If it's a mobile home he probably has it 2-12 pitch roof I would use roll roofing instead of shingles hope this helps
Adhesives,... | Answered on Mar 19, 2020
There is no effective long term way to store tubes of silicon. Even unopened tubes have a finite shelf life. I have found the most effective way to store opened tubes for medium lenght time, is to allow a bit of excess to flow over the tip, and allow it to form a plug. In a few months, this plug may extend the full length of the nozzle, but you can push this out with a piece of steel rod (from the tip end). I keep my tubes of silicone and caulking in a cool dry place. I've never tried the bucket of water method, so I don't know how successful that would be.
Adhesives,... | Answered on Jan 02, 2019
First start the cleaning process, clean all dirt and debris from the concrete driveway surface. Use concrete caulking or concrete sealer to fill the crack. With the help of troweler fill the crack properly and make smooth surface. Now let the driveway be dry. Now coat the concrete driveway with concrete sealer oil-based polyurethane to make the driveway water-resistant. Finally you can use colored concrete patching compound to match with the previous driveway color.
Adhesives,... | Answered on Sep 21, 2018
On pre-mixed buckets, a lot of dry-wallers add just a little water and whip it up when tape and texturing. It flows of the blade better. But, if you're just repairing a few holes, dings and gouges, then no real need............unless it's really thickened up on you.
If you have a partial bucket and are not going to use it for a while, you may want to flick some water on the surface and lay Saran wrap on the surface, then cap the bucket.
Adhesives,... | Answered on Mar 12, 2018
The best product that will not harm the poster or window is silicone caulk. There are also some crystal clear adhesives made from silicone now available.
Adhesives,... | Answered on Nov 19, 2017
Tip
How to get superglue off fingers
Through necessity when nothing else was available, I found that acetone / nail polish remover dissolves or at least softens superglue.
After the back of a folded tube burst, hands covered in the stuff, I tried various products.
Hand soap, dishwasher, Handy Andy and Methlylated spirits have little effect.
Laquer thinners also helps a bit, although acetone seems best.
Pour full bottle into glass or metal container - not plastic, which will melt..
When rinsing hands in acetone, rub & scrub to remove stubborn bits still stuck.
Concentrate under fingernails, where skin and nail meet.
After removal, re-bottle actetone for future use.
Lanolin oil in skin will also be removed, so after acetone-bath, wash well with hand soap, rinse, treat skin if required with a moisturizer cream.
If your'e a guy, live with it - it'll give your hands a manly, rugged outdoor look! :)
on Oct 19, 2017 | Adhesives, Coatings & Sealants
no this is overkill. the seem tape is only necessary for seems, screw holes can be covered by a coat of joint compound, and sanded smooth after it dries
Adhesives,... | Answered on Jul 27, 2015
They're not the same thing, spackle is used to fill in holes or indetations made from nails in drywall while joint compounds are used to join drywall panels together.
at least 2. I would suggest to look closely after the second coat dries. if you have a smooth transition than it is fine, if not, a third thin coat should make the finished product look better
Silicone-based caulk is often applied to the underside of bathroom sinks in order for the caulk to seal the gap between the sink and the wall, preventing moisture from getting underneath the sink.
Adhesives,... | Answered on Apr 20, 2015
It's a waterproof sealant used in household repairs and building.
Adhesives,... | Answered on Apr 16, 2015
You should coat your deck using a roller or a paitbrush I haven't seen anyone using an air brush. This could be because it can be hard to get into all the nooks and crannies in the wood using an air brush.
Adhesives,... | Answered on Mar 17, 2015
The time it takes for the joint compounds to dry depends on brand that your using. Generally 12 hours is enough, I like to let it dry over night.
Adhesives,... | Answered on Mar 16, 2015
GREAT STUFF Big Gap Filler Insulating Foam Sealant 16 oz. $4.96 at Home Depot. Comes in a spray can with straw.
Adhesives,... | Answered on Feb 02, 2015
Rustoleum Rust-Oleum Epoxy Shield Professional Semi-gloss Dunes Tan Floor Coating Kit 203846 Logo
1 questions posted
Top Rustoleum Adhesives, Coatings & Sealants Experts
Richard Piatek
Richard Piatek
Andrew Taylor
Andrew Taylor
Are you a Rustoleum Adhesive, Coating and Sealant Expert? Answer questions, earn points and help others
View Most Popular
  • Rustoleum Adhesives, Coatings & Sealants
Most Popular Question
husband painted our garage last night
  • Adhesives, Coatings & Sealants
