20 Most Recent Samsung DMR57LFS Stainless Steel Builtin Dishwasher Questions & Answers
What is mean error oE water level
Samsung DMR57LFS... | Answered on Aug 22, 2017
Samsung Dishwasher 0E Error - We had other appliances on that circuit. We believe when those appliances were turned on it created an undervoltage condition in the dishwasher, causing another sensor to send the high level error code 0E. We believe this is the problem because it only started after we added the new hot water dispenser on the same circuit. The problem went away when we leave it off for the whole dishwasher cycle. I'm guessing it could also be caused by brown-outs and other large electrical loads cycling in the same household. That's the theory anyway. The folks who sold us the dishwasher suggested turning off the breaker, to reset the computer. Good idea, but not for our particular case.
Samsung DMR57LFS... | Answered on Dec 28, 2015
That error code indicates a drain error or problem. Many times it is caused by something stuck in either the drain hose or drain pump, obstucting the water flow, or blocking the drain pump impeller itself. This is not an easy job, nor one recommended for the average home owner. You will probably want to call a professional dishwasher repair technician. I would recommend calling Sears Home Services at 800-4MYHOME = 800-469-4663.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Samsung DMR57LFS... | Answered on May 17, 2015
I have a Samsung stainless steel tub dishwasher and only 2 months after we had it installed we had all sorts of issues with it. We were lucky it was under warranty and turned out parts needed to be changed - upgrades from Samsung that were not done i nthe store where we purchased the dishwasher.. You may want to check with Samsung with your Mode land Serial Number you never know, there might of been a recall. Good Luck!
I’m happy to help further over the phone at https://www.6ya.com/expert/charles_6bf94c079488b145
Samsung DMR57LFS... | Answered on Nov 30, 2014
if it is the rear corner then you may have a leak in the drain line. take off the kick panel and see if you can tell where for sure it is leaking.
Samsung DMR57LFS... | Answered on May 16, 2014
check thermal fuse in the control section
Samsung DMR57LFS... | Answered on Feb 21, 2014
its the fuse, its located under the dishwasher. take off the bottom white plate, its on the right side of the pump on a wire harness. Its in a fuse cartridge turn to the left take out fuse and replace with 15 amp fuse take it radio shack and have it matched.
Samsung DMR57LFS... | Answered on Feb 20, 2014
Hello, tom
I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Samsung DMR57LFS... | Answered on Nov 25, 2013
The Samsung DMR57LFS Dishwasher has a 15 Amp/250VP Volt Fuse located on the lower right side of dishwasher behind an aluminum panel held by two screws. Pull dishwasher out from counter, remove lower rectangular aluminum panel, and it is just inside underneath. Unscrew fuse holder and replace fuse. I had to pay a Samsung Authorized Repairman $109.70 to replace a simple fuse. I learned the hard & expensive way. Samsung won't tell you to check the fuse underneath the unit. They won't even tell you that there is a fuse underneath on the right side. The fuse protects the Printed Circuit Board or Blue LED Control Panel in the event of a power surge or lightning strike.The less than $4.00 fuse will blow first.
Samsung DMR57LFS... | Answered on Aug 05, 2013
This is not as bad as it looks, the Pump motor is more challenging. If your sump needs to be replaced then do the following. Unplug the unit, shut off the water, and remove the racks. Next remove the wash pipe that goes from the sump to up the back and over the top, it just pulls out but be gentle. Next remove all the screws on top of the screen and pull that out. You will see a gasket seal that is either stretched or broken. Next remove the white Pump wheel by turning the screw clockwise (the threads are reversed so it does not unscrew when the pump is running). Now pull up on the grey plastic wash pump housing. You will see the grinding blade that pulls off the wash pump motor shaft. There is your sump. If you need to change the pump you'll have to turn the unit over. Chances are all you'll need to do is really clean out the sump and replace the stretched out seals, available online for about 15.00 or so. Reassemble and start washing. good luck.
Samsung DMR57LFS... | Answered on Nov 29, 2012
I have the same problem with gunk and spots on dishes. I took apart the parts at bottom covering the heating element. There is all sorts of gunk on everything. I cleaned it all, even under gaskets and filter screen. I am neither sure what caused it nor how to prevent it. My thinking maybe the water source. Water in my town has gotten worse in quality and has bad smell. I use a major water filter system for drinking water. My thought is that the heating element is drying the water up and leaving sediment from water.
Samsung DMR57LFS... | Answered on Oct 25, 2012
Samsung DMR57LFS Stainless Steel Builtin Dishwasher Logo
83 questions posted
Top Samsung Dishwashers Experts
Marvin
Marvin
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Samsung Dishwashers
  • Samsung Dishwashers
Most Popular Question
samsung dishwasher no power display off
  • Dishwashers
