20 Most Recent
General Electric GE Profile Dishwasher 24 in Builtin Dishwasher Questions & Answers
The dishwasher is 4 years old. It is not cleaning
Hi, try removing the spray arms and see if they are clogged - and of course unclog them. Also might be inlet valve. If you are at all technical, find it, remove it, see if it is clogged - if you have hard water - which most people do - it will clog up and should be replaced. You can use vinegar and special cleaning agents but most likely the problem is as aforementioned.
My ge e profile made a strange sound...smelled
There are several areas to check..
The wierd smell.. you didn't exactly describe it. If it is a rotten smell or an electrical or burning smell etc.
Also you did not mention where it leaked.. front or back...or under sink..
However I suspect you may have a clogged drain or the dishwasher drain hose was installed AFTER the trap under the sink..or improperly installed lacking a "high loop".. check the manual and inspect the drain hose to ensure it is installed correctly. If it was installed after the trap instead of before you could have sewer gas coming back into the dishwasher.. not good to say the least.
You can also pull the dishwasher out to inspect the drain hose connection on the back of the unit. However that is a pretty unusual occurence.
You can also check the drain inside the dishwasher for debris blockage.. I have also seen unrelated items cause bad smells.. like a plastic lid or untensil that melted onto the drying element.. .so Remove the dish racks and carefully inpsect both drain and element.
Remember the element may be hot if the dishwasher has just finished that cycle.. so be careful!
Check the float.. it has a hood on it.. make sure it moves freely up and down.
A few other areas to examine.. the door and counter top. If the door is hard to close or rubs the couter top underneath you may not be getting a good seal.
Also check the colour of the door gasket.. if grey.. examine the corners.. you may need a kit or replacement parts for this. Go to the GE website for those and the instructions.
Also check the holes in the spray arm for blockage.. even a little bit of buildup can cause them to spray against the front door.. the door is actually more of a water resistant barrier than a totally watertight one.. beleive it or not.
Lastly excess sudsing can cause several problems.. use the reccomended rinse agent and detergents.
Dishwashers make all manner of sounds.. things can shift around during the wash cycles and become struck by the spray arm..
If the plumbing is not done correctly you will need to assess your comfort vs skill levels to correct. If it's just a clogged drain.. you can attempt unclogging up to a degree.. then call in a professional to snake it or even use a device (little camera)to inspect it.
Good Luck!
It still has bubbles at end of cycle in the bottom
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...Dishwasher Spray Arms not SpinningHow to Buy Appliance Parts OnlineA bad heating element causes many problems in dishwashers...Dishwasher Problems The Heating Element not WorkingDishwasher Maintenanceheatman101
Our dishwasher will not drian out all the way. I
hi Richardcr1.
After having examined many dishwashers that were replaced because they wouldn't drain
, the largest percentage of them were simply because of a clogged drain
hose or pump strainer. Too many people seem to think that the dishwasher
is first cousin to a garbage disposal. It is not
.30 Apr 2010
https://www.ifixit.com/Answers/View/.../Does+not+drain+the+water+at+the+end+of+cycl...
How do I fix my dishwasher that will not drain?Check for a clog:Make sure the kitchen sink drain is not clogged.If a disposer is installed, run the disposer to clear the drain system. Do not put hands into the garbage disposer. ...If an air gap is installed, remove the cap and remove any debris. ...Do not use drain cleaner in the dishwasher.Dishwasher Does Not Drain - Products - GE Appliancesproducts.geappliances.com/appliance/gea-support-search-content?contentId=16240Search for: How do I fix my dishwasher that will not drain?
How do I unstop my dishwasher?
Turn the breaker off for five minutes and the turn back on. Start the dishwasher and see if it will drain. Sometimes power bumps can mess with the control board. Otherwise it could be the control board or the pump.
Model 7000
Pull the inside panel off to see what is going on with thr relat that controls this. Probably ther is a leak that has caused some corrosion on this assembly.
