20 Most Recent
Fisher and Paykel DishDrawer DS605FDSM Stainless Steel 23 in Builtin Dishwasher Questions & Answers
F1 Error code
F1 is flood error. basically water has arrived at the bottom board. you can unplug the dishdrawer, remove the bottom drawer and dry the board at the bottom, maybe with a hair dryer carefully. this will reset the fault, but this is a fault that may appear again. replace the actuators that close the lid of the drawer that is leaking (look for signs of water running our of one of the drawers).
Dishwasher keep beeping F1 and F5
F5 is the fast and rinse LED
It simply means the lid motror current is to high during the start - The lid is jammed up or down. Or the electronic controller has failed!!
Need to remove front drawer panel
There are two plastic bolts on each side of the dishwasher drawer holding the front cover. Get a plier to pull these out but make sure the cover is supported so that it does not fall down.
see
installation manual page 7. The location of the plastic screws is shown in insert diagram of notation 6. This is for a later model but yours should be similar.
Hope this helps. Wonder why you want to remove the front cover?
Power cannot be turned on. led display not on
Check that the draws are closing properly and evenly , there is a door sensor just inside the frame top and bottom on the right side .If thr machine is not level the doors can slide forward.if this does not work , feel if the draw really locks in when closed because at the back of the draw slides on each side are two plastic lock mechanisms. when the draw has been out they need to be upwards facing so when closed thy lock the slides in on both sides . Sometimes thy only lock in one side causing it not to deactivate the door sensors and shut down . Yes it sounds simple, but most problems i have found are
Soap residue left on glasses after the wash is complete
A good quality rinse aid and forget economy mode its a waste . Also leave the dishwasher drying until it stops , it can be hard to hear but the LCD will still be on . also most plastics will be left with a soapy looking stain permanently .How much powder and use a goog quality one. another common problem is the soap dispenser being left open or coming open during the cycle.
check the drain hoses and the inlet tap is turned on enough
Cheers
