That reset sequence code didn't work for me. We tried everything on a ton of forums. What I did to fix our Whirlpool dishwasher was to disconnect the drainage tube from the garbage disposal. I noticed it smelled really bad so I figured it was clogged. I used a bucket to catch the water left in the tube. I took the sprayer from the sink and flushed out the tube. 4 pumpkin seeds and a couple of beans landed in my bucket. I flushed it a couple times. I hooked the tube back up to the disposal and sure enough all the lights returned to normal. I pressed start and it came on.
using tape measure measure your item of here is dimensions. you can buy a DW that is 24 inches wide, very easy to do. It is a standard size DW
Width23.875"Depth24.5"Height33.875"
Try a mainboard Reset. Pull the mains plug before bed tonight. Tomorrow, press and hold the on button for 30 seconds, then let go and plug it back in.
My plan was to see if I could find you a service manual, but strangely, the only reference to that model number is your post here! My guess is the D6 is 'D for Dishwasher' and 'Series 6' or 6 models in that current series.
If the machine has been laid up or little used, check all the connection on the control board. Clean pins and plugs with electrical switch cleaner
https://www.google.com/search?q=DU940QWD6
Most likely a bad heating element..
https://www.youtube.com/watch?v=am-fhX92rbw
You can call Repairclinic 800# too, and talk with a tech, before throwing parts at it. 800-269-2609.
Best to you.
Miniplayer (i)
We'll also want to shut off the inlet watersupply and disconnect that as well.
0:30/8:42
Please refer to youtube " Whirlpool Dishwasher Repair - How to Replace the Pump (Whirlpool # W11032770) "
The loud popping noise that you're hearing when you open and shut the door of your Whirlpool dishwasher (model # WDT780SAEM1) is most likely caused by the door gasket. The door gasket is the rubber seal that runs around the door, creating a tight seal when the door is closed.
Here are a few things you can try to fix the issue:
Check the gasket for damage: Inspect the door gasket for any tears, cracks, or other damage. If you find any damage, you will need to replace the gasket.
Clean the gasket: Over time, debris and food particles can accumulate on the gasket, causing it to become stiff and not seal properly. Clean the gasket with a mild detergent and warm water, and then dry it thoroughly.
Check the door alignment: Make sure that the door is properly aligned and not hitting the gasket when you open and shut it. If the door is not aligned properly, you will need to adjust it.
Lubricate the hinge: If the door gasket is in good condition and properly aligned, the problem may be with the hinge. Try lubricating the hinge with a silicone-based lubricant, as this can help to reduce friction and noise.
Contact Whirlpool: If you have tried all of the above steps and are still unable to fix the issue, contact Whirlpool customer service for further assistance. They will be able to provide you with additional troubleshooting steps or advice, or they may need to send a technician to repair or replace the dishwasher.
It's important to note that if the popping noise you're hearing is accompanied by other symptoms, such as leaks, then it may be related to a different problem, and you should contact Whirlpool customer service or a professional service technician for further diagnosis and repair.
Es posible que la luz Soak & Clean del lavavajillas Whirlpool Gold Quiet Partner III no se encienda si el lavavajillas no est? recibiendo energ?a o si el lavavajillas no est? en el ciclo correcto. Se recomienda verificar la fuente de alimentaci?n y asegurarse de que el lavavajillas est? enchufado y reciba energ?a. Si la alimentaci?n est? conectada y el lavavajillas est? en el ciclo correcto, entonces es posible que haya un problema con los circuitos o el cableado del lavavajillas. Se recomienda ponerse en contacto con un centro de servicio autorizado de Whirlpool para obtener m?s ayuda.
