20 Most Recent
Magic Chef CDB1500AW 24 in Builtin Dishwasher Questions & Answers
I have a Magic Chef
You have an intermittent contact somewhere that vibrations will every once in a while restore contact. I would clean and crimp every stinking electrical connection in the unit including the door switch. You do that, and I am sure the unit will be fine..
My dishwasher is not cleanin at all and residue (I
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...Dishwasher
SprayArms not SpinningHow to Buy
ApplianceParts OnlineA bad heating element causes many problems in dishwashers...Dishwasher Problems The
HeatingElement not WorkingDishwasherMaintenanceDishwasherResidue and Film on Dishesheatman101 Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Bottom sprayer not turning
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not SpinningHow to Buy Appliance Parts OnlineA bad heating element causes many problems in dishwashers...Dishwasher Problems The Heating Element not WorkingDishwasher Maintenanceheatman101 Asker
11/12/2010 10:04:10 AM •
Magic Chef...
Answered
on Nov 12, 2010
This is a magic chef, only a few years old. I use
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
I push start and my dishwaher wont turn on. I have
either:
- something blocks the door from latching or closing. Check, if anything is stuck behind a dishrack. try reversing lower rack. check if the door aligns properly and dishwasher is installed correctly
- latch switch failed/latch mechanism is broken. Disconnect dishwasher from power. Disassemble door, check latch, check latch switches for continuity
- touch panel or control board (less likely) is failing. replace if none of the above is working for you.
Good luck,
Vlad
First Choice Appliance
Dishwasher doesn t dry
A simple solution would be to not select Heat Dry if you have that option on your machine. When the washing cycle is complete, open the door partially (4 to 6 inches) to allow the hot water vapors to escape.
Evaporation will dry the dishes in the lower section and the warm dishes can be returned to your cabinet.
Glasses, etc., from the upper section can be removed and stored.
In the remaining space on the upper level. Cups that may have some water remaining in the depressions at the bottom of the cup are turned horizontally in the basket so the water from the depressions can drain. Some minimal wiping may be necessary prior to storage.
Not only have we solved the drying problem we have added some humidity to the air; do not have to worry about a non-functional switch and reduced our electric bill as well.
As a side note, once all of the above has been completed we never close the door completely but leave it an inch or two from a complete close; this will not compress the door gaskets and will add to their service life.
Hope this helps!
Dishwasher not draining
Check the very bottom strainer in the dishwasher first. Clean it out and then (as long as the pump is good) the washer will drain.
