20 Most Recent Viking VDB450 Dishwasher Questions & Answers
WHAT DOES FLASHING POTS & PANS X1 FOLLOWED BY NORMAL WASH FLASHES X3
you have an electric problem
12/18/2017 4:03:43 AM • Viking VDB450... • Answered on Dec 18, 2017
manual
Door switch problem
I have an Amana dishwasher about 6 years old. I have changed the door handle Assy. 4 times , It is very easy. Remove all rthe inside door tork screws and you and pull off the black and white wires on the inside handle micro switches.... the put in new switsh put the wires back on... blacl on the right and white on the left. put your screws all back in and it will run again great. good luck! now if I can find out why the dish washer cycles 4 times and shuts down and all the lights go out i would be happy....... anyone know.... pump seems to be working when it comes on....
10/10/2012 7:43:40 PM • Viking VDB450... • Answered on Oct 10, 2012
My viking 450E start button is not working - the cyle buttons light up blue and then the start button should start flashing so that you can press it to start but the start button never flashes - I hav
It's likely that the cheap POS start switch under the button has fallen off the cheesy plastic mounting and the button isn't contacting it. Put it back so the ears on switch are under the slots in the panel and dab a TINY bit of super glue where the tabs go into the panel. www.appliancefixxa.com
9/28/2012 11:19:49 AM • Viking VDB450... • Answered on Sep 28, 2012
VDB450 VIKING DISHWASHER BLINKS ONCE ON NORMAL AND
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
To replace check this link:
http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
Thank You for using Fixya
9/30/2011 4:37:54 AM • Viking VDB450... • Answered on Sep 30, 2011
I have a one week old Viking dishwasher 450E has
Hello & Welcome to FixYa
John, the problem is with the door switch assembly that is bad and needs replacement, if that tests fine then replacement of control board is recommended. Please get back to me if you have any other questions.
Kevin
9/6/2011 9:18:10 PM • Viking VDB450... • Answered on Sep 06, 2011
Dishwasher is shutting off. I select the wash and
Hello Maureen Johnson, welcome to FixYa.
I'll start by acknowledging your post indicates the problem is with your dishwasher not starting/functioning, however if you could post the complete model & serial number I would be better equipped to help you further. If you could also verify it is a Viking (built by Asko) as the header suggests.
I'll look forward to your reply and try and help you move forward from there.
Thank you. Regards,
Macmarkus :)
7/22/2011 3:49:30 AM • Viking VDB450... • Answered on Jul 22, 2011
Viking Dishwasher VDB450SS Unit appears
Check the door latch switch mechanism as that seems to be bad and needs replacement as everything else is working fine. Please get back to me if you have any other questions.
Kevin
6/18/2011 11:16:02 PM • Viking VDB450... • Answered on Jun 18, 2011
I have a viking dishwasher that is not a year old
can you please confirm which light is blinking.
Does it take in water before it stops?
Refer page 34 and 35 in this manual once you check which light is flashing.
Hope this helps.
5/15/2011 11:17:04 PM • Viking VDB450... • Answered on May 15, 2011
Lower spray arm came off, part broken which holds
Hello, welcome to FixYa.
I believe the part you're referring to is called the lower spray arm bearing. It should be listed as part number 8057067-77.
This part is available at "repairclinic.com" for around $20USD. It will include what is shown here...
The part on their site actually appears upside down so I've rotated it 180degrees as it should appear. Let me know if you have any further questions and I'll try to help in any manner I can. Good luck.
Regards,
Macmarkus :)
4/27/2011 3:19:49 AM • Viking VDB450... • Answered on Apr 27, 2011
Dishwasher does not fully drain.
If the drain pipe is accessible, take it out of the trap pipe that it should be sitting in, place the open end in a bowl and lower the bowl to the floor. If you are lucky, the force of the water may bring any blockage with it. Does the water drain and was there any solids in the water? If the bowl starts getting full, simlpy raise the pipe upso that the open end is above the level in the dishwasher and the water will stop.
If no solids came out with the water, it sounds as though the pump is not running. If no water comes out at all, then you have a full blockage, usually caused by congealed fat. Take the strainer out from the inside of the dishwasher and have a look.
Come back if still not sorted.
4/23/2011 1:26:22 PM • Viking VDB450... • Answered on Apr 23, 2011
First of all, I'm not 100% sure what make my
Hi
The issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills your dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with your dishwasher's filling and/or draining ability. Use your voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If your switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
4/3/2011 8:37:41 PM • Viking VDB450... • Answered on Apr 03, 2011
We have this dishwasher at our firestation and
Hi, Welcome to FixYa. If you pull the kick plate/toe panel off you should see the junction terminals. Make sure there are no wires burnt up or loose. Let me know and we can go forward from there. Regards, Macmarkus :)
3/21/2011 2:51:06 AM • Viking VDB450... • Answered on Mar 21, 2011
Dishwasher viking model vdb450ss error
Hello there,
If you're certain this model number is correct, the error code indicates a "drain timeout error". This means the machine has tried and failed to pump out within a specified time limit. Please run through the following checklist to correct this problem:
1. Check and clean the filters
2. Check the drain hose isn't kinked and check for any blockages in the drain hose.
3. Make sure the hose has a high loop as per the installation instructions
4. If draining into a garbage disposal . . .
- Remove the plug from the disposal to allow air entry / eliminate any potential vacuum.
- Run water through the disposal to check for blockages
5. Ensure dishwasher is level, front to back and left to right.
When you've checked all of the above, reset the dishwasher by holding the START button for a minimum of four seconds to clear the error message.
My slight question mark over the model number is because you referred to "heavy cycle". The VDB450SS does have a heavy cycle but it's called "pot & pans" on this model. Other Viking dishwashers explicity say "Heavy" but a flashing LED above heavy on another model may indicate an entirely different fault. This is an overfill error code on some models.
If you definitely have the VDB450SS, you should be able to solve the problem using the checklist above. If you have any other model. please reply to me by clicking on "Add a Comment" below your question for further assistance. Please verify the correct model number if/when replying and whether any other LEDs are also flashing.
Thanks,
BElectric
3/11/2011 5:34:49 PM • Viking VDB450... • Answered on Mar 11, 2011
Viking VDB450 Dishwasher Logo
45 questions posted
Top Viking Dishwashers Experts
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Viking Dishwashers
  • Viking Dishwashers
Most Popular Question
lower spray arm came off part broken
  • Dishwashers
