20 Most Recent Danby DDW1899WP Portable Dishwasher Questions & Answers
2answers
Danby dishwasher not washing
see this possible causes: 1) water heating cycles;the water must be preheating,test the heating elements and thermostat. 2) Timer: test for defective, clean contact, repair any wires loose, burn, or break. 5_9_2012_1_15_39_pm.gif
4/21/2022 1:53:02 AM • Danby DDW1899WP... • Answered on Apr 21, 2022
4answers
New dishwasher already wet inside when opened for first time! Is it ok?
Sounds like it was in a flood. I'd sure try to send it back. Be blessed.
6/10/2021 6:05:21 AM • Danby DDW1899WP... • Answered on Jun 10, 2021
I have a Danby DDW1899WP portable dishwasher. I
I realize the above question is almost 4 years old, but I am sure others are still having this problem. My Danby was behaving the same way: drying cycle light would flash like it was having a myocardial infarction, and the cycle would stop. I could only get the light to stop flashing by turning the unit off. What you didn\'t say above is what happens then: everything most likely returns to normal-- or at least, so it seems. I have now had this happen to me two times in a row with my Danby 1899WP. Each time the machine has started up just fine, drains water out, loads in fresh water, and begins the wash cycle, only to freeze up with that damn flashing red light on the dry cycle and the dishes not clean. I have owned it for about two months, and so far this is my only complaint. I am running it again right now, for the third time, and we shall see what that light does now.... Will report back afterward!
6/23/2019 2:38:59 PM • Danby DDW1899WP... • Answered on Jun 23, 2019
I see a couple of posts about the dishwasher not draining. Mine drains just fine until the final rinse, it goes into the drying cycle (which I do not use) full of water. Any ideas? The manual is ve
To the lady who has water at the bottom of dishwasher. Guess what? It’s supposed to be there. At the end of last rinse cycle the water is at its hottest point. So. Instead of draining this vary hot water it saves it to dry your dishes. Wait about 10 or 15 minutes and water will drain. This is a vary efficient way of drying dishes. It uses no power for drying. Just steam
From the heated water. When it’s all complete the DW will beep 4 or 5 times. After that leave the door down to evaporate moisture. Good luck!!!
12/25/2018 2:04:09 PM • Danby DDW1899WP... • Answered on Dec 25, 2018
I bought a brand new
If it's only two months old I would talk to the place I bought it from. I am sure they will help you. It should be under warranty.
5/30/2017 1:10:13 AM • Danby DDW1899WP... • Answered on May 30, 2017
0answers
Making a buzzing noise and wont start up
repair clinic dot com may help.
9/3/2016 6:06:49 PM • Danby DDW1899WP... • Answered on Sep 03, 2016
Danby portable dishwasher ddw1899wp starts taking in water and then stops working with pre-rinse light blinking. Please help me on this issue. Any answer would be much appreciated.
If the water level sensor does not electrically shut off when the level needed is reached, the pre-rinse cycle will error out thinking that the level has not been reached. That sensor is a float device and probably needs to be replaced...
8/14/2014 5:28:48 AM • Danby DDW1899WP... • Answered on Aug 14, 2014
Why does washing cycle start but does not complete
The final phase on dial is a pre-wash. Separate from wash cycle.
7/7/2014 11:37:21 AM • Danby DDW1899WP... • Answered on Jul 07, 2014
Danby DDW1899WP Portable Dishwasher Logo
79 questions posted
Top Danby Dishwashers Experts
nu267
Gil Shultz
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Danby Dishwashers
  • Danby Dishwashers
Most Popular Question
danby ddw1899wp portable dishwasher
  • Dishwashers
