20 Most Recent
HTC Droid Eris by Questions & Answers
I want to lock texts and delete unwanted ones
You select the text message that you want to lock, hold your finger on the message until a menu appears and scroll down to lock message. Once locked a lock should appear in upper right hand corner.
Then you can select the thread of messages that you want to delete from the list, check the box that states you want to delete all messages including the locked ones.
HTC Droid Eris...
Answered
on Jan 26, 2017
Moto G text signature
Actually it does, see below:
To add a signature to each sent message:
1. Select OK > Messaging > Settings > Text Messaging.
2. Highlight the Add Signature field.
3. To have your phone add your name to each text message, select On.
- or -
To have your phone add a custom signature to each text message, select Change Signature, enter the closing you want to sue, and press save (left soft key)
HTC Droid Eris...
Answered
on Apr 06, 2014
Forgot lock screen pattern takes me to username
IDK about a simple legitimate fix for this. I was just messin around with the pattern, hit "forgot pattern" to see what it does. It asks me for the Google username and password, but has no way for me to go back! I know the pattern! The Motorola Droid is free from this problem, when on the forgot password screen, it still allows me to go back to the pattern screen. Very disappointing HTC...
On the other hand, there is a bit of a "hack" that can be used to solve this. Create a new Google account. Then call the locked phone from another phone. While in the call, you have full access to the phone. Press home, go into your settings, and add your new Gmail account into the phone. End the call, go back, and enter your new Gmail info. You may also need to enable Wifi while the call is still connected, I'm not sure if 3G will work for the sync while the phone is "locked".
HTC Droid Eris...
Answered
on Apr 05, 2014
Locked out of my from my pattern
Factory reset(but this will erase all your user data) unless your phone is rooted and have USB debugging enabled and know how to use ADB, then you can pull the gesture.key from the phone memory and use rev skills to brute force it.
HTC Droid Eris...
Answered
on Dec 07, 2013
I charge my eris all night and only gets 40% life
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
HTC Droid Eris...
Answered
on Aug 21, 2012
HTC eris screen is froozen!
Frozen Screen problem mostly occurs when one has recently updated the phone software.
If that's the case with you taking battery out should have helped.
Try resetting it this way.
> Turn the power off. Take the battery off and then re-insert it.
> Hold the Volume Down button
> Hold the Power button until the display turns on
> You are now presented with a menu that allows for Clear Storage.
> Select Clear Storage by pressing the Volume Down button
> Press and release the Power button to select
> Press Volume Up for Confirming your action.
>>> If you selected YES, the phone will reboot to its factory fresh state and would also wipe all 3rd party applications.
HTC Droid Eris...
Answered
on May 25, 2011
