20 Most Recent
LG GT505 Cell Phone Questions & Answers
My lg gt505 is work
Formatting a phone doesn't make it do anything for it. There's actually no such thing as "formatting" a phone.
You can delete programs, texts, call logs, pics, and other stuff that might be slowing it down. That usually helps.
Or you can do a factory reset, lose all your media and start from scratch, as it was, out of the box.
But I'm sorry. There is no formatting a phone to make it work better. Their phones, not computers
Hello...! I'm an owner of
how slow is your phone? have u tried switching off your phone? or resetting it? u can reset it in the setting menu. if it is still slow go and change your phone from where you buy it.
MAC address
The MAC address is the unique identifier for your network device. You can try to add the MAC address directly to your WiFi router in case someone turned this feature on you router.
To see your MAC go to "Settings - Wi Fi - Options Button - My MAC address".
Automatic shutdown
Not a real technical solution but if the original battery is still being used then there is a chance the battery is not holding the charge. I've had this issue in the past with a Motorola Droid and after the battery was replaced it held on for a few days instead of a couple of hours. Depending on phone use and charging methods older batteries will not hold a charge for long. I would recommend trying to get a battery saver app from the Google Play store to see if it helps as well. Again, this isn't a real tech solution but I hope this helps you along some. =)
Hard reset
Try this, 1. With the phone powered off, press and hold the Power and Volume Down buttons simultaneously.
2. When the Factory Hard Reset screen appears, release the buttons.
3. Press the Power button, then press Power again to confirm your selection.
Be patient as the phone performs all steps and restarts.Or if you have access inside of the phone try this,
From Android OS
1. Select Settings > Storage > Factory data reset.
2. Check the Erase internal memory box if you wish to delete personal data like music and photos.
3. Tap Reset phone > Erase everything.
Keypad
change keypad belt becouse jumper is damage your keypad belt conectorso beter change your keypad belt.
Lg gt505 virus
Hello My Dear:Please Attach Your Mobile Deta Cable In Your Mobile And Attach Your Pc and please Install antivirus in your Computer and Scan and virus Remove so your problem will Solved.
