20 Most Recent
Visual Land VL-768 (4 GB) MP3 Player Questions & Answers
My keyboard will not work on my new visual land prestige elite
1. If your keyboard is not Bluetooth-enabled, it will never work with your tablet.
2. If your keyboard is Bluetooth-enabled but your tablet is not, it will never work with your tablet.
3. If both your keyboard and your tablet are Bluetooth-enabled, connect your keyboard to the tablet using Bluetooth as per the set up instructions that must have come with the keyboard.
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
