20 Most Recent Element Electronics ELCHW261 26 in. TV Questions & Answers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
Element... | Answered on Aug 15, 2014
Take the batteries out of the remote. If the problem stops, the remote maybe needs cleaning. I don't think it's a Quark in the programming. If you're handy with a soldering iron, look for cold solder points on chips. And any other component.
Element... | Answered on Jan 18, 2014
1. is the tv connected to pvr ordvd or is it directly connected to wall cable.?
2. is power cord properly inserted at both ends?
3. try direct cable connection to wall to check if ok. Then reconnect to other devices.
Element... | Answered on Aug 07, 2013
Could be failure of the internal power supply
Element... | Answered on Mar 14, 2013
I would try Ebay or try google to see if you can track down a panel. The panel you need is a M260TWR1 R1. The problem you may find is that it will cost more to replace the screen that what the set is worth.
Element... | Answered on Feb 14, 2013
Sounds like you have a backlight fault. To verify this, turn on the TV, dim the lights in the room. Take a bright flashlight and shine it on the screen. If you see a faint picture you have a backlight problem. Do you feel comfortable opening up your set?
Element... | Answered on Jan 20, 2013
Replace the power supply board. You can get the replacement power board from www.tvrepairworld.com
Element... | Answered on Nov 12, 2012
The manual for many Element TVs are available from the company's support site: http://www.elementelectronics.com/support/ . They have a couple of different 32" TVs listed in the drop down menu list of model numbers. Which model do you need a manual for? The manual for the ELDFW322 is available near the bottom of http://www.elementelectronics.com/2011/12/eldfw322/?model_number=ELDFW322 .
To print the manual, either open the PDF with Adobe Reader (or a similar program) and print (File > Print) the file to a printer connected to your computer or put the file on a USB flash drive or optical disc and take it to your local print shop.
I hope this helps. Please post a comment with your model number for additional support.
Element... | Answered on Oct 02, 2012
Check its back-light inverter board. Replace it.
Element... | Answered on Aug 21, 2012
Element Electronics ELCHW261 26 in. TV Logo
70 questions posted
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Element Electronics Televison & Video
Most Popular Question
element elchs261 wont turn not even red
  • Televison & Video
