20 Most Recent
Orion 24RTC 24 in. TV Questions & Answers
Hi i have an orion 24in led tv, I use it for my
You have a bad "signal board".Some call this the main board. In this case the T-con board is in the signal board (main board) and not a separate board,as other TVs have. You will need to replace the board that has been reworked. A new replacement board will fail. Visit Sansui.com and ask for a reworked board. Thanks for asking. Matt of Martins TV Repair.
Can I hook a genie Wi-Fi camera up to this TV, ORION MODEL NO:TVDVD092
It's possible to connect a Wi-Fi security camera to a TV, but whether or not it will work with your specific TV model will depend on the capabilities of the TV and the camera. In general, most modern TVs have built-in Wi-Fi connectivity and support for applications like Netflix and Hulu, which allow you to stream video from the internet directly to your TV. However, not all TVs support all types of Wi-Fi cameras, and some cameras may require additional hardware or software in order to be used with a TV.
In order to connect a Wi-Fi security camera to your TV, you will need to check the specifications and compatibility of both the camera and the TV. If your TV has built-in Wi-Fi and support for streaming applications, it may be possible to connect the camera directly to the TV using the Wi-Fi network. Alternatively, you may be able to connect the camera to a computer or mobile device and then use an HDMI cable to connect the computer or mobile device to the TV.
In summary, it's possible to connect a Wi-Fi security camera to a TV, but whether or not it will work with your specific TV model will depend on the capabilities of the TV and the camera. It's best to check the specifications and compatibility of both the camera and the TV in order to determine the best way to connect them.
Can a wifi geeni camera be set up to my ORION MODEL NO:: TVDVD092
It is not possible to directly connect a Wi-Fi Geeni camera to an Orion TV model number TVDVD092. The Orion TV model you have mentioned is a television set that is not capable of connecting to a Wi-Fi network or functioning as a Wi-Fi network device. In order to use a Wi-Fi Geeni camera, you would need a device that is capable of connecting to a Wi-Fi network, such as a smartphone, tablet, or computer. You can then use the Geeni app on that device to set up and control the camera.
I need the multi screen control system disk and also need to know what would be the best Remote Control Receiver Set at a reasonable price
This is not really a question. Please rephrase it and be specific. Please keep in mind that some of us answering your question has never come in contact with your product- we answer off intelligence however it is far more difficult to answer your questions when we have to figure out accompanying information on our own. Normally sets that allow multi screen (putting together multiple sets to make one big tv) use some type of splitter (cdmi) and then each tv needs to be set to the position it will be in etc. the remote recover is a another story and mostly depends on preference. Do a little research and find out whats needed to get what you need, and we will help you along, but please be specific about what you need and want and the steps you have taken. good luck
https://www.6ya.com/mrmmike
