20 Most Recent
Samsung P2370HD 23 in. TV Questions & Answers
Tv turns on by itself and lights accross the bottom flash
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "
Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Samsung P2370HD...
Answered
on Mar 31, 2014
Was using my P2370HD as
Samsung
P2370HD is just Monitor that can be used with Computer only. It does not have inbuilt tuner or AV input to hook it with any other video source like cable box, dvd player etc
Click HERE to download instruction book that has all details about P2370HD monitor.
There is an alternate way to use this monitor as TV, hook it with TV Tuner Box that has DVI output port and plug coax cable in box to get cable channels transmission video signal in monitor and plug audio output in external speakers. Click Amazon.com to view TV Tuner Box for $95
Let me know if you have additional question.
Thanks.
Samsung P2370HD...
Answered
on Sep 18, 2010
Samsung P237HD tv/monitor,unit buzzing when on.
I would take it back unless you have time to investigate the problem before the return policy expires.
If the sound is coming from the speakers then it is interference and would likely happen with another TV.
The interference type can be electromagnetic or radio frequency, both of which can be defeated.
Start with plugging it into a different outlet. If that doesn't work, then unplug anything from it one device at a time to see which thing is the culprit. If it is one of the devices, move any audio cords away from power cords and/or position the device further from the television.
Household appliances and fluorescent lighting also can cause signal interference in electronics that is audible.
A device known to help with such interference are power line conditioners from such brands as Tripp lite, and ferrite clamps. You can place ferrite clamps on the power cords of your devices and their analog audio connectors.
Samsung P2370HD...
Answered
on Jun 18, 2010
