20 Most Recent
Sanyo DP42849 42 in. HDTV Questions & Answers
Can i install a amazon fire tv stick the u s b will not plug in
www.
amazon.com/
Amazon...
Fire-
TV-
Stick/.../B00GD...
Amazon.com, Inc.It doesn't even play all the games that can run on the Fire TV box. Also note ... Q: CanI use my TV's USB port to power the Fire TV Stick? ... A USB port on your TV or other equipment probably will not work. ..... You can plug the Fire Stick's USB cable into theUSB port on your TV and it should work (depending on your TV ).
www.
amazon.com/forum/
fire?cdForum...cdThread...
Amazon.com, Inc.Getting a brand new replacement from Amazon did not help, seems to be some other HW or SW issue. Anyone else run into similar issues? ... I also have a Samsung TV and the Fire Stick is not recognized through HDMI or USB connections. .... Can youplug the HDMI extender cable into your TV and will the Fire TV stick fix
Sanyo dp42849 picture is slow
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Where is the inverter board located in the sanyo dp42849
My tv randomly freezes and and shuts off and them comes right back on and sometimes it squeals when doing that,i was told it was a power supply board,but replaced it and still the same,could the probe
Loud screechy sounds, random turn-off and especially random restart are usually associated with the main board, not the power supply and not the T-CON and not the inverters (when separate).
Of course exceptions are always possible, but the rule is still that the above symptoms point to a bad main board.
Samsung has lots of main boards that develop a symptom of power cycling at startup, freezing image with loud screeching sound and eventually totally dead (although totally dead is also exhibited by main boards from every single manufacturer I know, so no much help there).
Anyway, this is 99.99% chance bad main board, especially considering it is known to develop a problem.
You can find repairs for the main problems of the Sanyo DP42849 and other series here:
http://www.coppelltvrepair.com/search?q=DP42849
Which brings me to the point that it is important to know which chassis version is your model. Some are quite different from others.
