20 Most Recent Xante Accel-a-Writer 4N Laser Printer Questions & Answers
Check the printer's memory modules for a good contact with the slot . Take them in and out a few times to shine the contacts.
Xante... | Answered on Apr 15, 2017
check sensors exit area...
Xante... | Answered on Jul 27, 2010
step 1>
remove netdevicemanager.msi from windows cleanup utility.
then try to install software again.
step 2>
remove netdevice manager from registry.
hklm > software > hewlett packard under hewlett packard you will find many {4dfg324.........} entries on left. if you will check each one of these code entries has its discription on right hand side of registry window. each one of these are for scan.msi, solution center.msi.... etc. fine out netdevicemanager.msi adn uninstall that {code} key from hewlett packard. these code keys may also be found in same location under hewlett packard under install key or installed options.
Xante... | Answered on Dec 15, 2009
its possible they are right, But try puting acoulpe of sheets of plain white paper behind the transparency before copying as a buffer . The scanner is seeing the transparency reflected back causing distortion. with the paper blocking the reflection, it should scan perfectly
Xante... | Answered on Jul 11, 2009
I had the same issue with 3 users and was able to solve it with a really easy fix. Set the dock to hide itself. I know it sounds weird, but there's a new print progress bar added to the CS3 icons, and that seems to be where the problem is caused. I'm assuming you have an Intel Mac?
Check out the blog post here if you want more info
http://techierambles.blogspot.com/2008/10/illustrator-cs3-printing-issue-status.html
Xante... | Answered on Mar 22, 2009
Just download the PPD Installer from here: AW4N_OSX then install the driver. Use System Preferences -> Print and Fax to create new Xante Printer using Default or Apple Talk section of Control Panel.
Xante... | Answered on Jan 16, 2009
Use the internet to search. For example type in SC324-05 using https://www.google.com and you will see multiple suggested fixes.
Xante Office... | Answered on Nov 13, 2019
Go online like everyone else
Xante Office... | Answered on Feb 07, 2018
Xante Accel-a-Writer 4N Laser Printer Logo
Popular Tags
20 questions posted
Top Xante Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Xante Office Equipment & Supplies
Most Popular Question
getting fatal error
  • Office Equipment & Supplies
