20 Most Recent Xante Accel-a-Writer 4G Laser Printer Questions & Answers
dear please find back cover and open it found big unit of printer called printer fuser assembly.removed it carefully you need one Philips screw driver,losses the two screw after that you removed screws slide it right side if you stand back of the printer,however after remove the fuser assembly you can installed it new in the Xante 4G printer when you install slide fuser to left side and alignment carefully,hope you understand.
thanks.
Xante... | Answered on Aug 18, 2016
I haven't checked in a while. Xante told me when I called them that they were not planning to make updates past the current version of the 4G OS X drivers, as the machine was no longer in production. They said the driver should perform adequately on current versions of OS X even though it was not initially designed for them (as they did not exist when the driver was created).
I found this to be untrue in my case. The drivers did not allow me to print consistently from 10.5.8 on an Intel Mac Pro.
My solution was to activate the print server on an Xserve running the Tiger server version of OS X, install the Xante driver there (since it was designed to run on that version of the OS), and now my newer macs can use the printer without issue.
Xante... | Answered on Jul 25, 2011
Locate the IP address of your printer (shown on the startup page or configuration page)
If you use firefox as browser;
Open the firefox browser
Go to the File menu and select Preferences
Click the Advanced (gear icon) across the top of the window
Select the Network tab and click the Settings button
Type the IP address of the printer into the field labeled "No proxy for:"
Click ok, restart FireFox and type the printer IP address to access the internal web page
If you use safari as browser:
Open Safari; Go to the File menu and select Preferences
Locate Proxies and select Change Settings; this will open the Network preferences
Type the IP address of the printer into the field labeled "Bypass proxy settings for these Hosts & Domains:"
Click Apply Now, restart Safari and type the printer IP address to access the internal web page.
For more details on setting IP you can refer the manual from the below link
Refer page 24
http://www.xante.com/support/aw4g/manuals/PDF/AW4G%20QuickRefManual.pdf
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Xante... | Answered on Oct 18, 2009
Very simple.Insert the printer installation software cd
First right click your cd drive and select open then go into the folder called util.
Then go into the folder called "CCC".
In that select uninstallation l3
once this uninstallation completes.
go into Local Disk C:\program files\hp\
and delete the digital imaging folder as much as can be deleted.
restart the computer.
goto hp.com and download the software for officejet 6500
After downloading it run it and when the type of uninstallation comes select advanced.
Next select custom installation and uncheck.
hp updates.
Hp Customer Participation Program
Hp Web Printing.
click on next first select usb installation and click on next(irrespective of whether it is a usb or wireless connection).
click on next and dont plug in the usb cable.
at the bottom there will be a box that says check this box if you want to connect your device later.
click on next.
the installation will finish.
Now insert your printer software installation cd and click on add a device or install and now you can choose your type of printer connection and your issue will be resolved.
Xante... | Answered on May 30, 2009
try this. Some of the terminology may vary as I had the solution in german. It came from Lexmark.
Open
http://localhost:631
-     click add printer
-   enter a name for the printer eg Lexmark or troublemaker ;-)
-     click continue
-    from the list chose 'LPD/LPR Hostprinter' and click continue
-     in tne next window enter lexnet3://IP (of the printer):1
-     click continue
-     chose Lexmark and click continue
-     chose your printer type
-     click add printer
This worked for me after reinstalling the printer via cd software.
Otherwise try the usb cable, you then have to go to printer preferences and change the usb printer to standard.
Strangely enough my printer used to work fine via W-Lan, suddenly I received that error. Perhaps du to an update to 10.5.6? I don't know. Hope thet helps, best regards Peter
Xante... | Answered on Jan 09, 2009
Yes, most likely they do. I don't believe there is much if anything that differentiates one toner from another other then the size of the roller and the shape of the cartridge. If these are the same and given that they use the same fuser, I would definitely try it.
Xante... | Answered on Oct 13, 2008
The 4g wil not be the solution for you.  It is just a basic graphics printer.  The filmmaker 4 will be the option you should look at.  It will produce negs and positives all the way up to 2400 dpi.
Xante... | Answered on Oct 24, 2007
Use the internet to search. For example type in SC324-05 using https://www.google.com and you will see multiple suggested fixes.
Xante Office... | Answered on Nov 13, 2019
Xante Accel-a-Writer 4G Laser Printer Logo
Popular Tags
17 questions posted
Top Xante Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Xante Office Equipment & Supplies
Most Popular Question
fatal error msi dot4wrp
  • Office Equipment & Supplies
