20 Most Recent Intuit Quicken Premier 2010 Full Version for PC (409970) Questions & Answers
print-screen-deluxe-7.jpg The Windows Print Screen Key can be a powerful tool if you know how to use it to its full potential. There are some who initially think that when they press the Print Screen Key that it will literally be sent to the printer! That's okay, we've all been there, done that. Just don't tell anyone! Actually, if you are using DOS, it will be sent to the printer.
Print Screen/SysRq
The key may appear differently depending on the manufacturer of your Windows keyboard. The standard position would be at the upper right hand corner of your keyboard and may appear within this sequence of keys...
F9 F10 F11 F12 Print Screen Scroll Lock Pause/Break
The sole function of this key is to take a snapshot or picture of your computer screen and copy it to the clipboard (the clipboard is an invisible holding area for content that is copied). Its the same thing as if you copied something from a document and it is now on your clipboard waiting to be pasted in its final destination. Its that simple. As quoted by Webopedia...
Often abbreviated Prt Scr, the Print Screen key is a useful key supported on most PCs. In DOS, pressing the Print Screen key causes the computer to send whatever images and text are currently on the display screen to the printer. Some graphics programs and Windows, use the Print Screen key to obtain Screen Captures.
Now, how do you get to see those Screen Captures or maybe even send them to someone? The quickest and most effective method is to have a graphics editing program handy. If that is not an option, you can open your favorite word processing program and create a new document. Position your cursorflashing-cursor.gifat the beginning of the document or wherever you want the screenshot to appear.
Using your keyboard, press Ctrl + V which will Paste the screenshot in your open document. Now you can Save (Ctrl + S) the document to wherever you wish, make sure to name it appropriately so you can easily find it.
You can now send this file to anyone via email, use it in a presentation, create your own little book of screenshots showing how to perform a specific task, etc. The possibilities are endless.
We use the Windows Print Screen Key regularly. You probably will too once you get the hang of it!
Sorry about the ad in the corner,Try the print screen key.
Intuit Quicken... | Answered on Jan 24, 2010
Intuit Error 15243
QuickBooks Error 15243 by Dylan on January 27, 2019 in QuickBooks Help 0
QuickBooks Error 15243 Overview QuickBooks error code 15243 usually pops up on the screen when the user is trying to update QuickBooks Desktop or is downloading latest payroll update. QuickBooks error 15243 may also show up when exporting transactions to excel. 15XXX series is very common series of errors in QuickBooks desktop. Usually, users get it fixed by applying simple troubleshooting steps provided by experts. The ugly thing about errors like QuickBooks error 15243 is they affect the workflow. Sometimes users get stuck in resolving these errors on their own. In these circumstances, users should get in touch with QuickBooks tech support experts to resolve their concerns quickly.
Causes of QuickBooks Error 15243
The various causes due to which QuickBooks error code 15243 occurs are mentioned below:
·Incorrect QuickBooks installation
·Intuit QuickBooks File Copy Service (FCS) is damaged
·QuickBooks FCS service is not enabled
·QuickBooks Payroll subscription has ended
·Damage in Company File
·User not logged in as an Administrator
QuickBooks Error 15243 - Intuit FCS Service is Damaged QuickBooks Error 15243, while updating QuickBooks desktop appears on the screen stating Error 15243: Intuit FCS Service is Damaged. This is because of the Intuit File Copy Service is disabled. Disabled FCS service is causing the error to update QuickBooks desktop. Intuit FCS service is an essential add-on service which manages file transfer during your QuickBooks desktop update. Below-mentioned steps are troubleshooting steps to resolve QuickBooks error 15243. Also helps when Intuit FCS is damaged.
Resolve QuickBooks Error 15243 in QuickBooks Desktop
·End all open QuickBooks windows and close the application
·Go to the Start button
·Right-click on Computer/This PC
·Choose Manage option
·Go to Services & Application Tab
·Double Click on Services option
·When you see Intuit QuickBooks FCS, click on it
·Click on the General Tab
·Click on Startup
·Choose the Manual option
·Click on apply
·Choose Start & then Ok
·Now, Reopen your QuickBooks as an administrator
·Open Company file & Update QuickBooks again
QuickBooks Error 15243 When Trying to Export to Excel
When QuickBooks user is trying to export workbook or worksheet to excel. He comes across QuickBooks error 15243. The reason for this problem can be the payroll subscription. To resolve this error go to Quickbooks Payroll account maintenance page to re-validate the payroll subscription.
Resolve QuickBooks Error 15243 in QuickBooks Payroll ·Open QuickBooks
·Go to the Employees option
·Choose My Payroll Service
·Select Manage Service key
·Click on the Edit option
·Verify your Payroll Service key
·Choose the Next option & remove the check for Open Payroll setup- I want to start right now
·Select the finish option
·After the verification, Go to Employees
·Select Get Payroll Updates
·Download Latest Payroll Update for QuickBooks Desktop & Update
Contact QuickBooks Support to Repair QuickBooks Error 15243 If above-mentioned troubleshooting steps for QuickBooks error 15243 doesn't help. Get in touch with QuickBooks support team by dialing +1800-316-0126. A certified team of professionals is available around the clock to help you resolve errors like QuickBooks error 15243.
Common Errors like QuickBooks Error 15243 ·QuickBooks Error 15271
·QuickBooks Error 15215
·QuickBooks Error 15101
·QuickBooks Error 15214
·QuickBooks Error 15203
·QuickBooks Error 15222
·QuickBooks Error 15262
·QuickBooks Error 15102
·QuickBooks Error 15106
Intuit Computers... | Answered on Jan 31, 2020
QuickBooks is a powerful accounting tool for your business. The tool gives you abundant features that help you benefit your business. QuickBooks software packages also come with great support functionality from the qualified experts. These qualified experts are the QuickBooks customer care team who deliver customer services to every small and medium-sized business owners across the globe.
You can call the QuickBooks customer care help desk number, which is a free toll-free phone number and is available 24-7. The QuickBooks customer care team of experts will assist you no matter what edition or version of QuickBooks you are using for your business.
QuickBooks support Helpline
Intuit Computers... | Answered on Oct 24, 2019
You can be in Quickbooks without bring online, but in order to use help you must be logged in; however you should be able to get into the check register without beng online.
Intuit Computers... | Answered on Dec 07, 2017
Contact Intuit for the validation code.
Intuit Computers... | Answered on Jan 06, 2017
Intuit QuickBooks can export lists, such as customers, vendors, items... Under file choose Export.
Once the lists have been exported, they can be imported into another file.
Intuit Computers... | Answered on Jun 29, 2016
Please call quickbooks (844) 414-4868 & have a tech help you so you dont loose sensitive info.
SUPPORT NUMBER: (844) 414-4868
Intuit Computers... | Answered on Dec 15, 2015
Hello Matt,
I too felt the same way and I have migrated to SimplifyEm Pay Rent. They are offering a free migration package for SparkRent users. I have already started availing their services and I feel it's really good. It has a lot of other useful features too. You can visit this link for more info: http://www.simplifyem.com/pay-rent
Sincerely,
Sara Pay Rent Pay Rent Online with SimplifyEm com Pay Rent
Intuit Computers... | Answered on Feb 27, 2015
This may be indicative that the system has been hit by a virus. Run a good anti-virus program like malwarebytes., then reinstall the software. If it still fails, you may have registry damage that extends to the OLE library files and a full reimage of windows may be needed.
Intuit Computers... | Answered on Nov 25, 2014
This error is caused by damaged QuickBooks installation files or by Windows user permissions. so try to Restart the computer and update your QuickBooks. for knowing complete guidance over follow Intuit Customer Service .
Intuit Computers... | Answered on Sep 18, 2014
For complete provided on Intuit site by Change your screen resolution .
For any help an support follow http://quickbooks.intuit.com/ .
it may because your Qbprint.qbp file is damaged, QuickBooks application file is missing or damaged or any reason. for complete troubleshooting follow Troubleshoot common printer problems and if need any guidance during this process follow Intuit Support .
Intuit Quicken Premier 2010 Full Version for PC (409970) Logo
1 questions posted
Top Intuit Computers & Internet Experts
Mike
SANTHOSH
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Intuit Computers & Internet
Most Popular Question
am having problem getting tax summary
  • Computers & Internet
