20 Most Recent
ValuSoft Are You Smarter Than A 5th Grader: Make the Grade - Windows Academic / Education License for PC (755142730925) Questions & Answers
Errors trying to run are you smarter thana fifth grader
Hello, I solved the problem by returning the software to the vendor for credit. I have book marked yourr domain for future reference. May your new year be filled with good health, safety and prosperity.
Sincerely, Bill Cross
When I exit Burn and Go X, I get a blue screen
The Burn & Go X software installation requires a preliminary installation of Microsoft Framework 1.1. I suspect this was not done and the software is trying to make use of later frameworks with which it is only partially compatible. The software is no longer in production. Indeed, it has been replaced.
10/5/2017 6:52:15 PM •
ValuSoft...
Answered
on Oct 05, 2017
I purchased the mysterious adventures
Go to the web site and find the game and it's description.
There should be a section describing system requirements. See if Win7 is listed/supported.
You can also try these two other options (may or may not help).
1) Try Running the install as Administrator
Right click on the file you want to run (install) and select "Run as Administrator"
2) If it is older software, try running/installing the software in in XP Compatibility Mode
To read about XP compatibility mode:
Go to start menu
Select Help and Support
Type xp compatibility in the search window
Select #2, Make older programs run in this verison of windows
There are instructions on how run the install using compatibility mode.
7/2/2013 6:58:25 PM •
ValuSoft...
Answered
on Jul 02, 2013
I am not able to
The files are in a format - .mc2 or .mx2 - and place that the program can't find.
If the file extension is *.mc2 , you add the cookbooks by using Windows Explorer to move or copy them to an MasterCook collection folder on your hard drive. Then open MasterCook and press F5 or Tools>Refresh file list for the cookbooks to be displayed in your cookbook browser. If you just double-click a mc2 file, MasterCook will open the cookbook and register its location so that must be avoided.
For the "MasterCook Export" files (these will have the .mx2 extensions), you should open MasterCook and then choose "Import" and direct MasterCook to those files. Do this with the target cookbook highlighted or open, and MasterCook will place them there.
By the way the 5 version is designed strictly for XP so there is a very high probability to fail if you try to run it in 7. For 7 you must buy and install the last version
http://www.amazon.com/ValuSoft-72066-Mastercook-11-0/dp/B003DO96FU
9/13/2011 4:52:44 AM •
ValuSoft...
Answered
on Sep 13, 2011
Bought Print Workshop 2007 LE
Try re-downloading the software (it should be free to re-download since you have already paid for it). Try to get clip art again. when it says insert disk, it should show a browse button where you can map to the file you just downloaded. if that doesn't work, run the installation file and do a custom install. You should be able to install the clip art through there.
3/12/2011 6:17:34 PM •
ValuSoft...
Answered
on Mar 12, 2011
I have ultimate mahjongg the
install CCleaner - http://www.piriform.com/ccleaner
click on tools > uninstall > select mahjongg > run uninstaller
running CCleaner (the home screen) afterwards wouldn't be a bad idea, either.
3/3/2011 6:32:28 AM •
ValuSoft...
Answered
on Mar 03, 2011
Ultimate Mahjong 15 is not
If you have a 64bit OS installed and there is o software that doesn't run on it you can always use a software to create a virtual 32bit OS. I recommend VirtualBox because it's free but you can try others too. Here is a list of virtual machine software:
http://bstdownload.com/cat/windows/system-utilities/virtual-machine-tools/
2/1/2011 10:21:40 AM •
ValuSoft...
Answered
on Feb 01, 2011
Why Does mastercook 7 shut
There are many possibilities. I could list them down in this way:
- Database corrupt/missing,
- Compatibility issues,
- Software/Driver conflict,
- Virus issue,
and many more.
First try repairing the program using the original CD or the Installer file so that it'd repair all the missing or corrupt files of the installed program.
Scan the system with few antivirus, like, avira, avg, avast, etc.. and try again (Note: not only one antivirus is enough, but don't ever install multiple antiviruses, it could bring system instability, if one of them is to be installed then, you have to first remove/uninstall the existing..)..
Let me know the outcome.
Awaiting.
11/3/2010 12:00:28 AM •
ValuSoft...
Answered
on Nov 03, 2010
I RECENTLY BOUGHT THE PC
What operating system you have and did u checked the recommended configuration for that Game
9/8/2010 1:59:52 AM •
ValuSoft...
Answered
on Sep 08, 2010
Hello: I recently bought
If you load a new version of an existing program, it may depend on the new program whether it will overide and revise the existing program or whether it will load as a totally seperate program; thereby having both old and new programs available and most likely 2 different icons on your desktop screen (one for each version).
Some upgrade (Newer) versions will give you the option of choosing to keep the old and have the new one loaded without any interference to the existing version, or to have the new version "take-in" the information of the existing version and then eliminate the need for existing program . In either case, you will not hurt or lose info (that already exits) when loading the new program .
8/10/2010 3:39:06 PM •
ValuSoft...
Answered
on Aug 10, 2010
Hi my name is ELEANOR
Hi Eleanor:
Flash Player is a free application you can download from
http://get.adobe.com/flashplayer/?promoid=BUIGP
Just copy that link above into your Internet browser and go to the website and click on agree and install now. Click on run. It will install and in minutes you will be able to play your game.
7/27/2010 8:31:47 AM •
ValuSoft...
Answered
on Jul 27, 2010
Como cancelar el winter driver
Question translated to English
Solo hablamos ingl?s en el sitio web norteamericano. Lamentablemente no tenemos idea de qui?n es este conductor de invierno. Por favor danos m?s informaci?n para ayudarte mejor. Es un problema de seguro de autom?vil, debe comunicarse directamente con la compa??a de seguros.
ENGLISH@
We only speak English on the North American website. Unfortunately we have no idea who this winter driver is. Please give us some more information to help you better. It is is a car insurance issue, you need to contact the insurance company direct.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
