20 Most Recent
Sony SPP-S2730S Phone Questions & Answers
I have a Sony QuadraStation 2H telephone, at work. I am trying
Strangely, I did what I detailed above, and it finally worked--after trying it numerous times. I have no idea why it worked after I wrote you, but thank you.
I went to the "Program" button, and, using the black bar as both a scrolling mechanism and an "Enter" key, scrolled to "Greeting," and selected "Record." I then recorded the greeting and it worked.
Problem with my handset identifying base phone
I can help you register the handset if it is functional. I am a former Sony Tech.
Hand lotion gets on the keypad and into the back of the rubber keypad. There is a conductive carbon on the back of the keypad to short the circuit board when you press the key. Oil makes it stop working.
Parts are no longer avaliable but you can glue a small piece of alumimum foil on the rubber.
For Register Handset Error email me I will walk you through the steps.
[email protected]
AL
Telephone calls
If I understand this right, you can not leave your base station off the hook this will cause the line to be activated. Just leave it on the hook.
Quadrastaion handset
I can help walk you through the setup. I just need to find my Cheat Sheet. I fixed them at Sony 6 years ago.
AL
How do I turn down the ringer volume.
For the base station set the ringer switch on the base from high to low. To turn it off select off. You can find that switch on the panel where the phone plugs into the wall on the far left.
The handset is adjusted the same way on the leftside as you are looking at the phone.
