20 Most Recent
Trendnet TEW-638APB 300Mbps Wireless N Access Point (TEW638APB) Questions & Answers
I have dsl modem routeur
You may be trying to connect through a G or B device to your N router. Verify that there are no serious obstructions or that the pc is not underneath something or enclosed. Metal near the pc can cause the signal to lose strength. Not having a wireless N card or adapter can also cause this.
Also if you are trying to connect through ethernet cable verify that windows is being assigned an automatic ip address, if it is static in windows change it to automatic.
12/29/2011 4:26:07 PM •
Trendnet...
Answered
on Dec 29, 2011
Setup code pin
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
5/30/2011 4:48:18 PM •
Trendnet...
Answered
on May 30, 2011
Screen blacks out on KVM
I have had this happen to me a few times. Usually it is the video card/driver. By KVM I assume you mean a KVM switch that goes to both computers, so you can switch between them? I have had trouble with them, too, so try putting the VGA straight to the monitor and see.
12/21/2017 1:25:51 PM •
Trendnet...
Answered
on Dec 21, 2017
Wi fi pasword
If you want to reset your wifi so you need to press wifi reset button click on it and hold about 20 seconds.
1/29/2015 7:40:06 AM •
Trendnet...
Answered
on Jan 29, 2015
